Question about Sony PlayStation Portable (PSP) Console
Help my problem is it will not read disk comes up with certificate utility
  • 31 Answers
What version of firmware are you running? Have you tried removing battery for a few min, or hard reset? What game is it? Support www.everything4psp.com
Posted on Aug 06, 2007
SOURCE:
Hard Disk not reading the content
It seem the folder is corrupted. I assumed you are using Mac, so you may try to repair disk using "Disk Utility". Since I don't know what version of Mac that you use, I don't know what to tell. You may try this link:
Use Disk Utility to Repair Hard Drives and Disk Permissions for your reference. Or, just google how to use Disk Utility. Good luck.
Sep 27, 2017 | Seagate FreeAgent GoFlex Home 1TB...
T22 disk read error
Sounds like the Operating System is corrupt. I would re-format the hard drive and re-install the OS that should solve the problem. If not then the Hard drive needs to be replaced.
Jan 23, 2012 | IBM ThinkPad T22 2647 Notebook
My 250g external appears to have corrupted data. windows says it fixed the errors but my last two attempts to back up my computer failed. How do I fix the external drive?
> fixed the errors
The disk-check utility does some "consistency" checks:
* every file listed in the the Table-Of-Contents actually exists on the disk-drive, with no exceptions,
* every file on the disk-drive is listed in the Table-Of-Contents, with no exceptions,
* every "block" of data on the disk is either "free", or used exactly _once_ by a specific file,
i.e., no block on the disk is unaccounted-for, and no block on the disk is "owned" by _more_ than one file.
The disk-check utility does _NOT_ read each "block" of data on the disk, to confirm that each block is "readable". Only when the file-backup attempts to read a file, does the inability to read that block get exposed.
Similarly, it's only when the file-backup utility is trying to write to one of the "free" blocks,
that the inability to write to that block get exposed.
So, what you need to do is to run the 'FORMAT' utility on the external disk-drive,
and to choose the "full" option, not the "quick-format" option.
The utility will try to write to each block on the disk.
When the utility detects a "bad" block, the utility will either flag that block as "never-to-be-used",
or the disk-drive itself will designate one of the "spare" blocks on the disk
as the permanent substitute for the "bad" block.
When the utility completes, it will either report the number of "bad" blocks,
or it will report ZERO "bad" blocks (because the drive's own electronic circuits
will have done that "substitution" in a "transparent" manner).
After the FORMAT completes, try your backup again. It should work.
Nov 03, 2010 | Toshiba Computers & Internet
Unable to restore back to factory image read error
Are you using Factory CD/DVD or Made from utlity Disks or from hard drive utility option.
This seems to be a CD read error.
I found the same error code need help for posted for HP, Compaq, Gateway, ETC.
ALL new setups with the MAKE RECOVERY DISK UTILITY and NO factory disks.
Factory recovery disks are available for $60 and up from manufacturers.
Other option is Install Retail OS - get drivers from manufacturer - Install software you want to use.
Other option is expensive but reliable.
Factory option would be for your system only.
Apr 05, 2010 | Computers & Internet
Can't read specific Zip 100MB Diskette
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
Jan 22, 2009 | Iomega Zip 100MB (31714) External ZIP...
Hard drive crashed
Hi, a restore disk uses data that is stored in a hidden partition on the original drive so when you replaced the hard drive with a new one, it will not have this hidden partition. You will need to either buy a new operating system, or contact your manufacturer/supplier to see what they can do, they may format the new drive with a hidden partition like your original depending how 'nice' they are. Only other thing you can do, is get hold of an original operating system disk from somewhere if you have a COA, (certificate of authenticity) on the computer, contact Microsoft and they should be able to replace your COA serial key with a new one that will work.
If any of this needs clarifying, or you have any other questions. Please let me know! Hope this helps :) Si
Oct 12, 2007 | Compaq Presario 5000 PC Desktop
Can not install Root Certificate
phones with win 2003 suppor digital certificates in DER format. If you have a PKCS12 certificate you will need to use a special program to import the personal and root certificates.you have to use a utility like P12imprt/Crtimprt/Enroll to install the certificate, run the program and follow the instructions to install the certificate.
Sep 14, 2005 | HP iPAQ hw6515 Pocket PC
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
