Question about Cell Phones
Nokia RM455 6350-1b
How to change the micro usb port
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
Charging port
You will need a new micro-USB port and some fine soldering skills. Unless you're a pro with a soldering iron and have the necessary tools, take it to one of those little mobile phone shacks you find at markets etc. They're usually run by Asian gentlemen and they can do all this kind of thing quite easily and cheaply. Have a go at it yourself, but you will probably need a lot of lights and magnifiers. Have fun!
Jan 21, 2014 | Nokia N97 Cell Phone
I want to download youtube and flv videos is not supporting this nokia 5233
you may try this downloader:
download.cnet.com/YouTube-Downloader/3000-2071_4-10647340.html
normally, it accepts & supports all nokia cellphones. If it is not, just download and run it on the computer and then transfer it thru micro USB port..
Sep 03, 2011 | Car Audio & Video
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Iwant to connect nokia 3600 to lap top to be able to download photographs
There is two main ways that you can transfer photographs to your laptop;
  • USB 2.0 Full Speed for rapid music transfer Nokia Connectivity Cable CA-101 - High-speed data transfer
    This micro USB cable provides high-speed USB 2.0 data transfer rates, and enables charging your compatible device or enhancement from a laptop or PC USB port.
  • Bluetooth 2.0 with stereo audio profiles for wireless music listening and control.
Jan 20, 2010 | Nokia 3600 slide Cellular Phone
Usb not recognized
if you use it on win 95 or win 98 or vista you need specfic drivers for you usb disk
if you get this on win xp please change the usp ports and use another port to insert the disk one of the ports has to recognise.
if the problem persists the usb port controllor on motherboards needs to be checked for faults or uninstalled drivers ,
if nothing works try a pci to usb internal card and dont forget to loaad drivers . this card has 3 to 6 ports for usb
Jun 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
