Question about Cerwin Vega Audio Players & Recorders
My Cerwin vega xls 15s doesn`t work!
The switch in the back that makes you choose between 110v and 220v was put on 110v when it should have been on 220v.... so now the subwoofer doesn`t work.. can somebody please help me???
  • Cerwin Vega Master
  • 17,093 Answers
Blown circuit. The question is; was it the power supply that blew out or was it the amp? check for fuses and see if they are ok. If they are not, replace them. IF they are then you are going to have to get new amp and or power supply.
Posted on May 13, 2013
SOURCE: Buzzing Cerwin Vega LS-12 Subwoofer
If it's not interference or a ground problem it might be a bad amp. I have the same sub and not only did I have the buzzing, but also a noticable "whacking" sound instead of smooth bass. I found an online seller who at the time just happened to have obtained some surplus Cerwin Vega amps that fit perfectly. Paid $60 shipped. Problem solved.
Posted on Feb 23, 2008
jsinex2421
  • 62 Answers
SOURCE: cerwin vega ht-10d subwoofer won't work in yamaha reciever
Actually, I had the same problem with my JBL PB10. It was the cable. I had to buy a one direction shielded rca cable. If you put it in backwards it will not work. The cable was around 75.00. But it was well worth it. The first cable I tried was a cheap sony brand sub rca cable. I ended up buying the AR(Acoustic Research) 15ft. directional subwoofer RCA cable from Best Buy. Make sure you have your receiver set to the proper setting too. If you have it hooked to main, set it to main. If you have it hooked to the L.F.E.(RCA cable) set it on L.F.E.. Some have the option to set to both. If it is a non powered sub a RCA cable will not work. You will have to run your main speaker cables to the sub first, then from the sub to the speakers. It then "piggybacks" the Low Frequency signals from the receiver.
Posted on Jan 08, 2009
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
  • 308 Answers
SOURCE: cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Posted on Mar 09, 2010
chrisreitano
  • 85 Answers
SOURCE: Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Posted on Aug 13, 2010
I am interested in disabling my Cerwin Vega XLS-215 tweeter protection switch. I am well aware of the ramifications of this modification. Is it in the crossover circuit and if so could you tell me how to...
http://www.cerwin-vega-fans.com/forums/viewtopic.php?f=24&t=1611
If you have a look at the above link, there are pictures of the crossover as well as the schematic for the crossover.
you will see in the second photo there are two yellow discs attached to the circuit board. you just need to remove these discs which are PTC Polyswitches, and replace both of these with wire links.
Feb 06, 2011 | Car Audio & Video
I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 13, 2010 | Cerwin Vega CLSC-12S Subwoofer
Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Jan 01, 2010 | Cerwin Vega LW12 Subwoofer
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
I HAVE A CERWIN VEGA CLS-15S POWERED SUB AND A PIONEER RECEIVER WITH NO RCA SUB HOOK UP ON BACK. HOW DO YOU HOOK IT UP
flathead30,
This is an old question but if you have not yet figured anything out, hear is a suggestion.
Without buying any other electronics, use your tape output on the receiver and let your sub's built in crossover to filter the highs out of the signal.
-Chris
Apr 16, 2009 | Athena AS-F1 Main / Stereo Speaker
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Cerwin Vega V-10S Subwoofer doesn´t sounds good
dear "rai17"
This, to me, is most likely the voice coil inside the driver rubbung against the yolk plate, or possibly the spyder slapping the metal plate underneath it, or the amp-(if it has one?) getting tired. this can occur from poor build quality, or playing the subwoofer too loud. depending on how much it cost you, you may want to get it repaired(voice coil re-alignment or something or new amp). But the way it seems, it is probably the driver itself. subwoofers get looser as they break in. This one may have been over-broken....sorry
I hope this helped clarify what is happening!
Oct 09, 2007 | Cerwin Vega V-10S Subwoofer
Cerwin-Vega EXL1000D Amplifier Broken?
Call Cerwin-Vega and they should offer a "Flat-Rate" repair for it. No matter what is wrong with it, for a flat rate, they will fix it. If not, most any repair shop should be able to. If not, heck, I'LL buy it off ya! (I love Cerwin Vega stuff...)
Sep 14, 2007 | Cerwin Vega EXL-1000D Car Audio Amplifier
273 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
