Question about Sony STR-DE845 Receiver
My sony str-de845 has an error
It will turn on whe plugged in and the display turns on for about 10 seconds than turns off and there is no sound at all the amp stays on and i cannot turn it off without unpluging it any answers i want to give it to my brother who doesn't have a good amp
    Genius:
  • Sony Master
  • 1,054 Answers
First I would try to reset it. With it off, hold the power button for about 5-10 seconds. It should either reset, or tell you to press enter to reset it.
Posted on Apr 26, 2013
renosean
  • 492 Answers
SOURCE: sony atr-de845
Open it up, check by where the power cord comes in there should be a fuse. Check to see if it is blown. If so it is an easy fix. Replace the fuse with same type. If not the capacitors are gone and that is expensive to replace.
Posted on Dec 10, 2008
SOURCE: sony str-de845 powers on, relay clicks sound works
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Posted on Jan 22, 2010
larry james
  • 287 Answers
SOURCE: sony str-ga7es stereo receiver/surround sound amp.
unplug it discharge output voltages with a 1k resistor then resolder the voltage driver ic's these ic's start with up, ie upc2558 , or stk350 etc. you will see the solder rings and cool solder joints around then. Use liquid flux and solder them back to the board. You might end up replacing them but youl never know until you try soldering them first. Larry's Electronics. ledstiles@hotmail.com
Posted on Apr 24, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sony STR-DE845 5.1 Receiver, No Sound
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 21, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Issue is the sound only stays on for two seconds and then silence for two seconds and then again and again.
Do you have an amp or it's this running through an amp? If so sounds like it's a thermal issue to hot. If it's not hot check to see if it's got a good connection on power or ground. I've seen this happen where the radio turns it on for a couple seconds the sees an issue and shuts back down. With or with out amp, could also be blown speaker shorting out. Can unplug one speaker at a time till radio stays on or check each speaker with an ohm meter, should read 4ohm with no current going into speaker. I've seen that happen also with bad RCA cables going to amp. If is an amp you can check the light on the amp to see if going on and off, unhook Rca cables then check to see if amp stays on. Hope that helps
Mar 05, 2016 | Audio Players & Recorders
Audiovox KLV3913 TV/DVD dead
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 06, 2017 | Audiovox KLV3913 12 in. LCD TV/DVD Combo
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
Wont turn on
2 days old and defective return for refund or replacement
Jul 12, 2017 | Motorola Mobility S9 Headphones
I just put a new steering column in my 200 saturn sl2 because my ignition lock was messed up. Now when whe try to start the car, it will start up but immediately shut off and then the security light...
Hello: Will try to give you instructions: Attempt to start car, leave key on (security light flashing) let set for 10 minutes, After 10 minutes security light out. Turn key off for ten seconds, turn key on, let set for 10 minutes, turn key off for 10 seconds. turn key back on let set 10 minutes, turn key off for ten seconds, the engine should now start and stay running.
Jan 14, 2011 | Saturn SL2 Cars & Trucks
2004 chrysler crossfire resetting service light
Disconnect negative battery post for 30 seconds & reconnect. This action will reset the car's computor & remove the light.
Jan 07, 2010 | 2004 Chrysler Crossfire
Computer keeps turning on and off, plus monitor won't display
Sounds like a loose wire inside the system touching something inside and shorting it out. My brother had this same problem. I brought it to my house to work on it and it was fine, no problems. Open the panel and look for any wires that are touching metal or something else and tie it up out of the way. I won't swear that is your issue, but sure sounds like it.
Jul 27, 2009 | Gateway FPD1975W 19" LCD Monitor
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
My xs 700 won't stay on
it is worse do you know why it problay be the xs 700
May 03, 2008 | Crown XS700 Amplifier
Sony STR-DE845 Receiver Logo
99 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
