Question about HP PSC 2410 All-In-One InkJet Printer
Hp2410 unable to operate
After plugging the unit in,it starts its cycle, then begins clicking like its stuck. After it stops clicking, the hour glass displays and the on button flashes.No other functions work.I unplug it and try again with the same results.
Solution #2 Above about unplugging overnight is the only way I found to cure this problem.
Posted on Aug 24, 2007
I had exactly the same problem after a power outage. I have tried uninstalling and reinstalling sw and drivers, and also various ways shutting the system down and starting again, but nothing worked. Then, I turned off the printer first, unplugged usb connection from the printer and unplugged the power. Then closed down the system the normal way. Let the entire system stay like that for about 6 hours, overnight. In the morning started the system. Connected power and usb to printer. Turned on. EVERYTHING STARTED WORKING again like before. It seems that this unplugging and waiting reset the printer to previous values. IF this does not work for you then try HP's resetting of the printer methods. If you contact them by e-mail, they will send you instructions. Good Luck. THG
Posted on Aug 14, 2007
    Scholar:
  • 161 Answers
Cleaning your appliance may very well take care of your problem. But if not make sure the drivers and the software have been installed. If they appear to be installed then uninstall them and restart your computer and reinstall them. If you have the same problem then take to a qualified service center.
Posted on Aug 06, 2007
  • Jessie Goss Aug 12, 2007
    You might look for objects stuck in your machine rollers and gears. But examine them carefully for there are many little parts that can easily be broken or bent with very little force at all.
Wash started cycle. Wife stopped it at beginning of cycle. Now washer will not start at at. Lid switch is good. Will not spin, rinse, restart wash, nothing, not even clicking.
Does unit have a reset button? If it has manual control for cycle did you try going clockwise to the start position and then restarting?
If she stopped the cycle by opening the door perhaps that switch is still stuck in an open position.
Aug 31, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Display reads F2
have you tried a hard reset and left unit powered off for few hours?
Jul 10, 2008 | Whirlpool Kitchen Ranges
Stuck on "problem detected" screen
Hi deejay961...You may want to begin with the following procedures. Please update your post with your results, and if needed, we can progress until we correct your issue....good luck my friend...chris The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature. "A problem has been detected with this unit" will be displayed on the screen. The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control. Solution: 1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT. 2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in. 3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 23, 2007 | GE WPGT9360EPL Top Load Washer
Samsung dryer where to press cancel on hour glass pops up
An hour glass on the display, it is normal. The hour glass is there to let you know that there is a cycle in progress.
Nov 24, 2012 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung DV410AGW Dryer My dryer which is brand new will not start. It appears to have an hour glass on the control panel which i have not seen before. dryer will not start even after i unplugged it...
Sorry to take so long. I have been talking to Samsung support. the hour glass indicates that the dryer is in a cycle, but as it wont start and you've tried unplugging it, it seems there is a fault. Your dryer is new, so you need to contact Samsung for a service visit:
http://www.samsung.com/us/support/service/request
Before doing this, try unplugging the dryer again and this time leave the power off for a few hours - assuming you haven't done this already. It might reset if you do this.
I've pasted a transcript of my conversation with Samsung below. I pretended to be the appliance owner as otherwise they would not answer my questions!
Hope this helps!
info: Please wait for a Samsung Agent to respond.
info: All Samsung Agents are currently assisting others. Thanks for your patience. A Samsung Agent will be with you shortly.
info: You are now chatting with 'Darlene'
Darlene: Hi, thanks for reaching out to Samsung tech support. How can I help you today?
Nick: Good evening
Darlene: I see that you are not chatting from USA. Let me know the place of purchase of the unit.
Nick: USA
Darlene: Please let me know the Samsung Unit model number you have. You can find the model number on the label attached to the right side of the Unit.
Nick: DV410AGW
Darlene: Let me know the exact issue you have with the Dryer, so that I can assist you to isolate and troubleshoot the issue.
Nick: Ok - the dryer is displaying the hour glass symbol, but it's not on a drying cycle
Nick: I tried unplugging it but it hasn't reset
Darlene: Let me know if the dryer works fine when you select any cycle.
Nick: it wont start
Nick: Is there some way of resetting the dryer? I think there is a programme stuck in memory
Darlene: Let me know if you are using Dryer in UK.
Nick: no
Nick: I'm working here for 2 days
Darlene: If your dryer is showing an hour glass on the display, it is normal. The hour glass is there to let you know that there is a cycle in progress.
Nick: I know this. I read the FAQ
Nick: But it wont start and the symbol remains even after it's been unplugged
Nick: Can it be reset?
Darlene: Let me know if you have tried to unplug and replug the unit from different wall outlets.
Nick: Cmon, be serious
Darlene: There is no option to reset the Dryer, only way is to unplug and replug the unit from power.
Nick: It's not my outlets
Darlene: I am sorry, a physical diagnostic is necessary to determine the exact defective part on your device.
Nick: I left it unplugged while I am away
Nick: I will try when I get home
Darlene: I recommend you file online service request to schedule service appointment, there you can get the Service Center information, so you can contact them.
Darlene: Would you like me to provide you with the link to fill out an online service Request?
Nick: Yes please
Darlene: Visit the link given below to file an online service request to get the Dryer serviced:
Darlene: http://www.samsung.com/us/support/online/supportOnlineServiceRequest.do
Darlene: Fill the required information to schedule the Service for your Dryer.
Nick: Please answer one more question for me . . .
Darlene: Sure, please go ahead with your question.
Nick: Is the dryer equipped with a memory so in the event of a power failure, it will restart when the power returns?
Darlene: When power fails, Dryer will start from the beginning of the cycle.
Nick: OK, so unplugging it should fully reset it?
Darlene: Yes.
Nick: OK, If that's the case I definitely need a service request
Nick: Thanks for your assistance
Nick: Have a good evening
Darlene: You're welcome. Is there anything else I can assist you with?
Nick: No thanks
Darlene: Thank you for chatting with us. If you have a minute, please click on the blue "X close" button to receive a transcript of your chat and fill out a brief survey to help us serve you better. Have a Good Day!
Nick: Goodnight
Oct 20, 2010 | Samsung DV410AGW Dryer
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
Will not start. control stuck on glasses cycle. display states "39" cannot change cycle or cancel
Go to the fuse pannel and trip the fuse breaker off and then put it on again. It will reset the automatic cycle. Vitally
May 13, 2009 | Frigidaire PLD4555RFC Dishwasher
Hp 2410 just clicking
When you power on the printer.
See if the scanner light move to the right and then keep on clicking.
If this happen, the scanner head is unable to find home position.
You will have to clean the strip under the glass.
If this only start to happen recently, you could unplug the printer and wait 1 hour.
Replug in the printer will at times stop the clicking.
You can go to http://h10025.www1.hp.com
Enter c00553775 into the search block.
Click on Hp All in one how to clean scanner glass.
This will bring you to the HP document.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Stuckon screen
Solution:
Oct 20, 2007 | GE WPGT9360EPL Top Load Washer
HP PSC 2410 All-In-One InkJet Printer Logo
776 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
