Question about Sewing Machines
Manual for sensio CM 4210-B - Sewing Machines
How do I put a bobbin holder securely back in a singer 4210?
it just drops in place and sits there like any good bobbin might
Jun 24, 2015 | Singer Sewing Machines
How to remove the bobbin plate?
Download the user's manual from the Singer site, www.singerco.com. It is a free download. Look on page 34, and it will show you how to remove the plate and clean underneath. There are two levers that must be set to release it.
Aug 11, 2014 | Singer Inspiration 4210 Mechanical Sewing...
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Singer manual 4210 in english
Go to http://www.singerco.com/accessories/instruction-manuals/search and enter 4210 in the search box. You can download the manual to your PC for free in Adobe reader format.
Jun 22, 2011 | Singer Inspiration 4210 Mechanical Sewing...
When I try to use my Singer 4210 with the feed dogs covered the cover plate pops off.
I was just looking at page 27 of your manual, and was wondering if one of your pins is broken off and that is why it won't lock in place. Take a look at it and your manual and see if that is the problem. Then call Singer at 1-800-4singer and see if they will send you another one. If, it is the first time you tried to use it, I am sure that they will help you for free. It probably was damaged when you got it.
Nov 20, 2010 | Singer Inspiration 4210 Mechanical Sewing...
I have bought a singer quick fix and I can not figure out how to load the bobbin to sew the instructions that came with the singer are in spanish
Hi
You can download a free manual from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 4210 and click on search.
On the next page click on free download!
This manual is in French, English and Spanish.
Hope this helps.
Nov 14, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Buenas tardes necesito manual para maquina singer 4210 mi correo es eduanis16@hotmail.com
Hola
Pinchas en este enlace para le sitio web de Singer.
Pone el numero de modelo en el espacio de busceda y presiona Search.
Aperecera otra pagina con los manuales, el segunda de la lista es lo que tu necesitas. Presiona en Free download! y ya etsa.
Tiene suerte esta disponible en Ingl?s, Franc?s y Espa?ol, cuando lo normal es que son todos en Ingl?s!
Sep 15, 2010 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
