Question about Audubon Society Audubon Singing Bird Clock
Sensor not working
Birds no longer chirp on the hour. Only way I can get sound is when I hit reset button. I think sensor has gone bad. Have put the clock in bright light, sunlight, etc but still no change The clock was set up properly according to the instructions & all worked fine. I've tried new batteries & totally re-setting the clock for hourly sounds but still nothing. Any advice?
My Audobon singing bird clock delivers the bird song if I push the button, but does not when it is hanging on the wall. It has a light sensor that "lets the birds sleep at night. I think the sensor is...
So, on a table it would work if you pushed the button. Hang it on the wall it wont. Are you covering a sensor? Maybe try putting it on the table and placing an object like a book behind it to simulate a wall. See if it still works when you push the button. If it doesn't work with this test you may be covering a sensor. If you have to re-route a light sensor it may be a weekend project.
Dec 11, 2013 | Audio Players & Recorders
Birds won't chirp on the hour on audobon society bird clock
If the clock is more than a few years old, it may be that the switch movement inside has gone out, or maybe the sound mechanism has gone out. You'd have to find a clock repair shop that would consider working on it. Search clock repair in your general area with whatever search engine you prefer.
Aug 09, 2013 | Home
How do I change the chime on my HPM wireless door chime? The sound of birds chirping is driving me nuts!
Taking the battery out and putting in back in will reset to a simple DingDong chime. It should be possible to put the doorbell in a mode that allows buttoning through each of the tunes.
Jan 12, 2012 | Home Security
The amber led labeled lamp lit up on my optoma ds303 and the picture disappeared. I replaced the original lamp with an after market lamp I purchased online. It worked for 2hours or so then the amber lamp...
the reason that it turns on without hitting the power button is that it thinks it's still in cooldown mode. while it's on, check the lamp hours through the menu. if it's close to 2000 hours (or the inside of the lamp is blackened or bulging), replace it. after market lamps never seem to last that long. if the fans stay on when the lamp goes off, it could also be the colorwheel. listen for chirping. if it chirps, it's the colorwheel.
Nov 17, 2009 | Optoma DS303 DLP Projector
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
How do i reset the tpms on a 08 implala SS after a tire rotation,without a owners manual
You have two minutes to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you need to start over.
The TPMS sensor matching process is outlined below:
  1. Set the parking brake.
  2. Turn the ignition switch to ON/RUN with the engine off.
  3. Press the Remote Keyless Entry (RKE) transmitter's lock and unlock buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
  4. Start with the driver side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for five seconds, or until a horn chirp sounds. The horn chirp, which may take up to 30 seconds to sound, confirms that the sensor identification code has been matched to this tire and wheel position.
  6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
  9. Turn the ignition switch to LOCK/OFF.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems.
Aug 31, 2009 | 2008 Chevrolet Impala
Gmc sierra 2008 low tire pressure problem
You can follow this to reset it.
Ignition ON, initiate the TPM Learn Mode
using one of the following procedures:
  1. On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  2. On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the TIRE LEARN message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  3. Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
    3.1. Right front
    3.2. Right rear
    3.3. Left rear
    When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
    Ignition OFF, adjust all tires to the recommended pressures
Jan 22, 2009 | 2000 GMC New Sierra 1500
2003 Cadillac seville sts TPMS reset
From 2005 STS Owners manual:
Each TPM sensor has a unique identification code. Any
time you replace one or more of the TPM sensors,
the identification codes will need to be matched to the
new tire/wheel position. Each tire/wheel position is
matched, to a sensor, by increasing or decreasing the
tire’s air pressure. The sensors are matched, to the
tire/wheel positions, in the following order: left front (LF),
right front (RF), right rear (RR), and left rear (LR).
You will have one minute to match the first tire/wheel
position, and five minutes overall, to match all four
tire/wheel positions. If it takes longer than one minute,
minutes to match all four tire/wheel positions the
matching process stops and you will need to start over.
The TPM matching process is outlined below:
2. Press the push-button ignition switch to OFF/ACC.
3. Using the Keyless Access transmitter, lock and
unlock the vehicle’s doors.
4. Press the lock and unlock buttons, at the same
time, on the Keyless Access transmitter. A single
horn chirp will sound, indicating that the TPM
system is ready, and the sensor matching process
can begin.
5. Start with the left (driver’s side) front tire.
6. Remove the valve cap from the valve stem.
Activate the TPM sensor by increasing or
decreasing the tire’s air pressure for five seconds,
which may take up to 30 seconds, confirms that the
this tire position. To decrease the tire’s air-pressure
use the pointy end of the valve cap, a pencil-style
air pressure gage or a key.
7. Proceed to the right (passenger’s side) front tire,
and repeat the procedure in Step 6.
8. Proceed to the right (passenger’s side) rear tire,
9. Proceed to the left (driver’s side) rear tire, and
10. After hearing the confirming double horn chirp, for
the left rear tire, exit the matching process by
turning the ignition switch to OFF/ACC.
11. Set all four tires to the recommended air
pressure level as indicated on the tire and loading
information label.
12. Put the valve caps back on the valve stems.
Oct 28, 2008 | 2003 Cadillac Seville
06 dts tire monitor reset button?
Programming TPM Sensors
1. Turn the ignition to ON.
2. Press the key fob lock and unlock buttons simultaneously for several seconds. The horn will chirp when the TPM
programming mode is activated. Important: If the TPM programming mode cannot be entered, check if the DIM is
configured with the correct RPO codes.
3. Starting with the Left Front Tire
4. Install the J 41760 over the left front valve stem. Magnets from Radio Shack, P/N 64-1888 (at $2.99), will also work.
They're too small to go over the valve stem cap, but once you remove it they slip over the valve stem just fine
instead of the GM tool.
5. The horn will sound, indicating the Left Front TPM sensor is programmed. Important: If the horn does not sound after
15 seconds, remove then reinstall the TPM sensor programming tool or place the magnet alongside the valve stem.
6. When the horn sounds, proceed to program the next TPM sensor in the following order:
o Right Front Tire
o Right Rear Tire
o Left Rear Tire
7. After the Left Rear sensor is programmed, the horn will sound twice to indicate programming is complete.
Programming Cancellation
1. The programming mode will be canceled if any of the following conditions are met:
o The ignition is turned OFF.
o All four sensors have been programmed.
o The TPM system has been in the program mode for longer than 5 minutes and no sensors have been learned.
2. If more then one minute has passed before the next sensor is programmed, all previously stored codes are
erased from the receiver's memory.
after driving around for a few blocks, if the pressure does not match the tire pressure for each wheel, then the sensor is bad.
Oct 15, 2008 | 2006 Cadillac DTS
Audubon Society Audubon Singing Bird Clock Logo
Top Audubon Society Home Experts
Donni Steen
Tom Chichester
Are you an Audubon Society Home Expert? Answer questions, earn points and help others
