Question about Nokia 6350 Cell Phone
Usb mini port, will not charge the phone
Will not charge, how do I change the mini port
2 Suggested Answers
SOURCE: my nokia 6708's benq charging port does not work
my blackjack the first ones charger port is not working
Posted on Oct 17, 2009
I have gfive mobile but when i plug the charger then showing bad contact charge,plz help me,i changed charging jeck,battary and charger but same result
If your old phone has the photos stored on a mini SD memory card, then remove the memory card and insert it into an USB card reader then connect it to the computer's USB port. The computer will see this as an external storage device, you can then open the folders and photos on this mini SD memory card and copy the photos into your computer.
Sep 04, 2011 | Computers & Internet
Can i charge my canon zr200 with usb?
Hi, I am not recommend you to use Computer USB port. This port only dedicated to power flash disc and some cellular phones. Voltage of Computer USB port is 5 VDC.
Regards,
Dec 15, 2010 | Canon ZR200 Mini DV Digital Camcorder
Charging my gpx ML638B
It will if it is a mini-USB plug. The mp3 has the mini-USB cord bundled, and can be used with anything with a mini-USB port. My cell has the same port, so I can charge it on the PC like the mp3, and can use the wall socket charger for the phone on the mp3.
Dec 18, 2008 | GPX ML648B MP3 Player
Battery do not charge using usb
There is a power limitation that the USB-port provides. This is 500mA (milliAmperes). Therefore, if your battery needs more power to charge (see the specifications) you will have to wait longer. If the difference between the limitation of the power on USB-port and your battery specification is significant, you will have to wait centuries before the battery is fully charged.
Nov 23, 2008 | Innovage Mini Flip Phone 1510255
My service port looks like an 8-pin mini din mouse port
If you are just trying to 'jump start' the tv to turn it on, get a usb cable, like the one you use to charge your cell phone. Touch the metal part of the service port, the 8-pin mini din witht he end of your charger cable that is plugged into the wall, until you see a flash on the screen, then turn the tv on like you normally would. It should turn on. If it doesn't jump it again.
Mar 16, 2008 | Olevia LT23HVX 23 in. LCD Television
Motorola W370 will not charge
Motorola provides a USB driver for just charging the W370. I installed it using the installation instructions from the Motorola website, but it just wouldn't work. The USB driver would install but would not activate (error Type 10). The W370 said that it could not charge. I recommend not bothering with this device driver, at least not with Windows XP.
However, I did figure out how to get the W370 charging from a USB port by trial and error. It's a pretty simple process.
1. Before plugging in the USB cable, turn on the W370 and wait for it to fully boot.
2. Connect the phone to the USB port of the computer.
3. When the phone asks "Connect phone as storage Device?", press the phone's left soft key, choosing "YES".
4. The phone will say "Please Wait...... Connecting Phone as Storage Device"
5. Eventually, the phone will display a white screen with the message, "In storage mode, no regular phone activities can be done."
6. Flip the phone closed. The yellow battery indicator will be lit. The phone is charging.
You'll note that the computer will see the W370 as a storage device with around 512 Megabytes of free memory, with empty "picture" and "sound" directories. The W370 appears to be a generic mass storage device to the computer. No special device driver is needed to charge the W370!
Mar 02, 2008 | Cell Phones
Mini usb, charge port
yes you can but it would be wise for you to take it to a mobile service center and have them do that for you professionally.
Jan 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Nokia 6350 Cell Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
