Question about Tefal Actifry Al800240 Low Fat Electric Fryer, 1 Kg Capacity, Black
Paddle goes round but no heat - Tefal Actifry Al800240 Low Fat Electric Fryer, 1 Kg Capacity, Black
Please help! The breadmaker is heating up but he paddle isn't going round at all. Thank you.
Time for a new one maybe as if the element or control board has failed it will be difficult to find replacements.
Mar 20, 2017 | The Kitchen Appliances - Others
How can I remove K beater from my Kenwood patissier which is jammed
Only a bit of CRC and some brute force is going to work. Unplug the machine. Remove the bowl, lock the head down, squirt some CRC around the top of the paddle where the shaft goes in. Get someone to hold the mixer from moving about then grip the paddle firmly with 2 hands and turn it left and right. Gradually you will begin to get increasing movement until in the end you will be able to unlock it from the shaft. Once it is off you will need to thoroughly clean the shaft then you will need to scrape out the inside of the hole in the paddle. I carefully use a small round file, I am trying to clean the hole out, not increase the size of it beyond what originally was. The hole size has become smaller over time because of flour or similar entering around the shaft during use.
Mar 01, 2015 | Kenwood Food Mixers
Paddle goes round but very slowly, and is not as noisy as normal?
the fan is stuck . Take fan cover off at the back , and spin it with a screw driver , But please do it quickly if you have it set to on . or try it first with plug taken out. Hope it solves problem
Stevemaxwell@hotmail.co.uk
Jan 14, 2013 | Tefal ActiFry Deep Fryer
Having trouble getting the kneading paddle on the post. Does not seem to fit. Is ther anything special I need to do other than push it on?
one side of the post is kind of flat and the other side is round. You need to line up the flat side of the hole in your paddle with the flat side of the post and then it should slip right on. You know that old saying " you put a square peg in a round hole" that is kind of what is going on with your paddle and post ....the 2 flat sides of the paddle and post have to be aligned.
Jan 28, 2011 | Oster 5838 ExpressBake Bread Maker
Having trouble with the brakes on my '90 Ford ranger. Replaced the master cylinder and still have very little braking power. Any help would be appreciated!
***Seek out professional help this vehicle is not safe to operate.***
Check the vacuum line going to the brake booster.
This is the big round chamber behind the master cylinder.
Hope this tip helps.
R/
David
Jan 23, 2010 | 1990 Ford Ranger SuperCab
Paddle shaft and seal replacement
Best bearing company I know of is Tri-State Bearing In Evansville IN. They have an unbelievable selection of high quality bearings. But you will have to specify ID, OD, thickness, material preference, sealed vs. unsealed and temperature range. Or you could try RepairClinic.com online and find parts by make, model, etc.
Apr 24, 2017 | Kitchen Appliances - Others
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washihg paddle won't stay in
There is more than one version of drum paddles, assuming you have got the right one, then locate the paddle in the slots in the drum, and push firmly into place, you should feel it click in to place, to check, pull the paddle lightly back towards you, it should remain fixed in place.
Also make sure you have got it the right way round.
Please rate my solutrion.
Thankyou.
Jan 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Need new paddles
Your best source is directly from Zojirushi. I ordered a replacement set of paddles when the teflon started flaking off mine.
The price was reasonable and delivery was quick. The zojirushi website is http://www.zojirushi.com go tot he Zojirushi Store! link to order parts. The blades currently list for $6.50 each.
Sep 01, 2008 | Zojirushi BBCC-V20 Home Bakery Traditional...
Tefal Actifry Al800240 Low Fat Electric Fryer, 1 Kg Capacity, Black Logo
32 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
