Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. To get the machine to finish the cycle I have to press the power button off and then back on, advance to beginning rinse cycle. It will then finish. Next load it does the same thing. Any help will be appreciated. Thanks Dan
  • Anonymous Mar 23, 2014
    Is there a reset button
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Posted on Aug 20, 2007
F&P washer stops spin cycle
You will need to check the out of balance switch under the motor controller board for corrosion and replace if faulty.
May 24, 2013 | Fisher and Paykel Washing Machines
Washing machine won't drain or finish cycle
It sounds like you have a drain pump stopped up or failed. Do you hear any noise when it is supposed to be draining? A humm or buzz?
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stops half way through rinse cycle and beeps
Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Gwl 10 fisher and paykel washer won't start
hi
if you can,t reset the module i would think that it is a module fault or display fault possibly moisture has got into one of the modules, if you can,t get into any service modes you will have to change modules
cheers grantsreps
Sep 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. The...
Plug off the wall. Open up behind the machine. Check to see if any wires loose. See that the wires from the control panel to the motor are plugged in tight. Vibration from the machine could loosen the wires and give the display wrong readings, or disrupt the run.
Rate me please..........
Dec 26, 2007 | Fisher and Paykel GWL11 Top Load Washer
Beeping and odd light sequence
I have the same problem with my 603 washing machine stopping in the middle of a cycle and i would have to go and manually advance the wash. I have just replaced the top curcuit board with a new one. can you please help or offer a solution. Thank you.
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
958 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
