Question about Daewoo DLP3212 32 in. LCD Television
No bbc signal and cannot click install
After retune still no bbc channels
2 Suggested Answers
Grubhead
  • 5349 Answers
SOURCE: hi i retuned the channels
It sometimes best to find the factory default settings on the menu and use them, then retune the vcr.
Posted on Apr 19, 2011
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
Lost bbc channels
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 04, 2014 | LG 32LD550 32 in. LCD HDTV
Have just moved house .....have retuned tv ....but cant get any BBC channels
Automatic scan cannot detect the BBC channels, possibly because they are too weak in your new location. It should be possible to add channels manually by using your remote. The setup function of your TV may give you the option of adding channels manually
Oct 14, 2012 | Grundig Televison & Video
After retune bbc redbutton not working
Found this when my Philips LCD TV lost the BBC RED button http://sparedparts.com/parts/details/philips-lcd-tv-bbc-red-button-no-longer-works
No BBC RED button
Apr 07, 2012 | Philips Televison & Video
After retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Nov 06, 2009 | Pace Televison & Video
My PVR has retuned (DSO)to the wrong transmitter. I receive signals from the Winter Hill transmitter and live in SW Cumbria. My Humax 9200T has retuned ok but my older 8000T has retuned to a transmitter in...
Not a complete solution but after much fruitless fiddling through the menu I eventually found that the programmes were actually there but under different channel numbers.
I searched a long way down the LIST of channels (on remote) The BBC1 channel I want is now 800 BBC. Selecting 1 on the remote still brings up BBC Wales.
This applies to my Humax 8000T PVR - I can't comment on other makes of Freeview box.
Nov 05, 2009 | Televison & Video
Loss of BBC channels
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Philips TV Tuner Video Capture PCI Card -...
Lost BBC channels on my SAGEM PVR6200T during a retune
Jul 06, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
No BBC 1 or 2 after digital switchover.
I have the same box and re-tuned mine with the same results as you.However i discovered that the NEW BBC channels were on the channel guide list starting at channel 800
May 07, 2009 | Televison & Video
Daewoo DLP3212 32 in. LCD Television Logo
18 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
