Question about Eliminator Lighting ELIM-134 - Star Blast System
How do you connect the cables to the lights?
I am having trouble connecting the cables to the lights. The lights just come on and that's it. They do nothing else like chasing and flashing. Not even the master unit does anything except just light up. Could the master be damaged. I am not sure because it does come on. Help please.
Lenovo laptop:check cable connection!
Deat
Replace the harddisk cable it will solve the issue
Apr 24, 2013 | Lenovo IdeaPad Computers & Internet
Can't light pilot light on hot water service. Gas to property is connected as the gas stove works.
There should be a trouble shoot guide on the hot water tank. I have had to do this many times. You just need to read the trouble shooting guide & be very careful. I hope this works for you.
D :)
Feb 01, 2013 | Water Heaters
Red light on modem's internet
I think incorrect physical connection between your router device and the PC.Because cable modem status light should be solid green.it indicates that your ADSL/cable modem has a good connection.
Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 27, 2012 | Computers & Internet
MB 2001 C320 still has battery drain issues after new battery and unplugged seat module
Here are the general instructions to find a battery parasitic drain, it is different for each problem and there is no magic bullet fix.
Instructions
    • Charge your battery if necessary. Dead batteries (and even weak ones) don't give accurate results on a draw test. The dome light is a good indicator of battery strength. If the light is weak, pulsating or refuses to turn on, you'll need to charge the battery.
    • 2Shut off everything in the car. Pull the keys out of the ignition. Ensure all service lights are off, lighted compartments closed and doors shut. Open the hood, and disconnect the trouble light underneath if your vehicle has one. Wait for 30 minutes before moving on to Step 3. (This enables normal drain from interior components to finish cycling.)
    • 3Set your battery tester to 10 amps DC. Disconnect your positive battery connection (red cable) and position it safely away from metal components. Connect the meter's positive probe to the battery's positive post while simultaneously holding the negative probe in the air; keep it away from anything metal.
    • 4Place the negative probe on the end of the removed positive cable to complete the circuit. Yes, you're putting a negative on a positive. Yes, this is ok. If you have a severe drain, you're likely to pop a fuse or two-identifying your problem.
    • 5Check the meter reading. A normal reading is usually under .035 amps. If you have a minor drain that causes a higher reading, you'll need to check each component.
    • 6Remove the first fuse in the box, and check to see if the load problem is resolved. If not, replace the fuse and check the next one. Repeat the process with all fuses. If the fuses check out fine, you have a wiring problem.
    • 7Remove the tester and reconnect the battery. Follow the hot wire to the next connection. Remove the positive cable and connect the positive probe of the tester in its place. Connect the negative probe to a metal object. Check the meter. If the drain isn't resolved, reconnect as normal and follow the hot wire to the next connection. Repeat this step at each connection point until you narrow down the problem.
Aug 10, 2012 | 2001 Mercedes-Benz C-Class
How to reset the airbag light on chevy impala 2009
Your not going to be able to diagnose the SRS (Air Bag)
System, without factory trouble charts to follow,way too
many codes & procedures to follow.
A battery is about $110.00 & the cables are only3 years
old,so they should be able to be cleaned
I would only guess, that they didn't do anything about
your intitial complaint on the Service Airbag light,not
for $100.00
May 22, 2012 | 2009 Chevrolet Impala
Can't sign into yahoo messenger.
marwan karm bekhet hesen mahamd
Apr 09, 2012 | Yahoo Messenger
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
When i connect the monitor VL2018W TO a power supply without connecting to my pc,i get the message ''NO SIGNAL,SELF DIAGNOSTIC'''.When i connect cable to pc,,there flashing blue light...
* Make sure the cable is connected properly.
* I've you have mutiple interfaces like HDMI & VGA, try switching between these until you get a signal :D
This can be performed by using the build-in options menu.
Jun 14, 2011 | Princeton Digital VL2018W Monitor
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Eliminator Lighting ELIM-134 - Star Blast System Logo
886 people viewed this question
Top Eliminator Lighting Water Sport Experts
Tom Chichester
Bill Boyd
Are you an Eliminator Lighting Water Sport Expert? Answer questions, earn points and help others
