Question about Compaq PRESARIO SR1475CL AMD Athlon 64 3400+ 2.40GHz, 512MB DDRAM, 200GB Hard Drive, LightScribe DL ... (PW711AA) PC Desktop
Want to connect to analog tv to watch movies from my computer
What cables do i need
    Brigadier General:
  • Compaq Master
  • 3,400 Answers
Try USB.
Posted on Apr 26, 2013
How to connect computer to a receiver or TV to watch movies in the TV saved in the computer
If you have HDMI in and out on both the Computer and TV, you can connect via an HDMI cable. Other than that, its very complicated with lots of wires, connectors, and rigging up the system.
Jan 18, 2014 | Dell Inspiron One 2330 All-in-One Desktop...
I connected my 32" Funai LCD TV to PC CPU with VGA cable. I could watch the movie once. However, not able to get the connection again. TV gives message "Not Support". Do i have to change the settings
Make sure your VGA chord is connected to both TV and Computer. Right click on your desktop and go to screen resolutions. Click on Connect to a Projector and click the Duplicate icon.
Jan 29, 2013 | Televison & Video
Need to connext laptop to my hdmi tv to watch movies
You need to get an HDMI cable and connect it to one of the open HDMI spots on the TV.
May 15, 2012 | Netflix
I have connected my yamaha amp with my tv and blu ray player. when i am playing a movie, the sound is coming out of the speakers but when i am watching the tv no sound is coming out of the speakers.
hi,
Do one thing get a stereo RCA cable and connect its one end to the audio output of your tv and other end to the any one of the analog input of the amplifier. when you watching the tv simply select the corresponding input in your amplifier to which you have been connected the RCA cable.
Also there is one more why if the tv has an optical output. connect the optical out put of you tv to any of the optical input of the amplifier. select the corresponding input when you watch the tv
ok
Feb 14, 2011 | Yamaha AX-596 Amplifier
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
I have an old TV, which is now connected to the digital-analog converter box. How do I add a DVD player to this (it's so a not very mobile senior citizen can watch movies). Thanks very much!
You need an RF convertor (available most electronis stores -Walmart) Check instructions of RF converter purchased
Guideline:
The video audio cables (R,W,Y) should be connected to the matching colors on the RF converter and the RF cable (standard cable)should be connected from the RF conv. where it say "to TV" to the TV and the TV should be set to either Ch3 o Ch4 (you can usually choose on the RF conv.) the cable from the cable provider should be connected to where it says "in from antenna or cable in on the RF conv.
Oct 19, 2009 | Apex Digital AD-1165
Hook up tv/dvd
All you need is A/V cable. These are yellow, white, and red. If you have an old model TV that doesn't have these, you can get an RF modulator from any electronics store, which will enable you to connect the DVD/VCR combo.
Sep 16, 2009 | Insignia Digital-to-Analog Converter for...
Need indtructions to hook up converter, DVD, VCR & antenna to TV.
please help me i can watch my movie since i connect my converter box.. i connected my video cable to the converter when i press play nothing is showing up PLEASE HELP..
Jun 11, 2009 | Insignia Digital-to-Analog Converter for...
Hooking computer up to tv to watch movie
Purchase a vga cable and hook it up to the computer and then to the tv
Jul 18, 2008 | Vizio L32 32 in. LCD HDTV
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
