Question about Sony STR-DE325 Receiver
Power no power/the fuse is ok.
    Genius:
  • Sony Master
  • 1,054 Answers
Does it click at all when you press power? Sounds like the power transformer may be bad. There is a thermal fuse inside of the transformer that can go open and cause a problem like that.
Posted on Apr 26, 2013
No power to fuel pump
What engine?
you say everything is ok but have you checked for power at any of these components to see where you are losing power. Check for power at the fuse. The fuel pump fuse should have two pins with power and two pins with ground. Check each pin while turning the key to the run position. There will only be power/ground on some of the wires for 3-5 seconds when the key is turned to the run position. It may be helpful to have a helper in the drivers seat turning the key while you test.
Sep 05, 2014 | 2000 Dodge Durango
My ac stop working,I checked compressor ,it's ok ,no power to compressor
Some possible causes are the system is low on freon, a faulty compressor clutch, faulty low pressure switch, relay, fuse, or control switch.
Do you have power at the fuse and the relay ?
Jul 15, 2012 | 2001 Chrysler Sebring
Fan motor won;t turn on blower motor is ok fuses are ok relay is ok but i still have no power at the switch what am i missing
sounds like the wire from fuse box to switch is bad, a fuse completes a circuit or route the fuse takes power in on one side and sends power out the other, I've seen it many of times but cant confirm its your problem. but the power comes in and the power goes out and the fuse checks good but on the out side it is not making connection to the wire or connector on the back of fuse box. run a jumper wire from a positive power source to the positive in on the switch does it work is there a good ground to the motor
Jan 14, 2011 | 2004 Dodge Dakota
Driver side power window doesnt work
Its possible, check underhood fuse box, the position 6, 60AMP for Power Windows
Other details can find in the Ford-Explorer-Owners-Manual (page 187 and next)
If the fuse is OK, take off the trim panel to check the windows motor, windows switch and wires.
Hope helps (remember rated this).
Jul 23, 2010 | 2003 Ford Explorer
Power turns off randomly
Hello :
First check the power cord ! If it's OK , then you need to check if the fuses are OK also . If fuses are OK , then the problem is with the power PCB . Fuses are easy to be replaced . Power PCB is a bit complicated . You need to take your coffee maker to a repair shop for that .
good luck .
rate please !
Mar 19, 2010 | Keurig Elite B40 Coffee Maker
No electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
Power outlets don't work. All fuses in both fuse
These are very simple circits, a power and a ground. Issues like this are usually a fuse, where the fuses checked with a test light, meter or just by looking at them? Fuses are decieving sometimes.
If they are ok, with a test light check for power at the outlets.If no power and the fuses are good then you may have a broke wire, or a ground issue. Let me know what you find.
Feb 19, 2009 | 2000 Dodge Caravan
Sony STR-DE325 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
