Question about Pool & Spa
Starite c48j2ec11c3 CAPACITOR - Pool & Spa
C48j2ec11c3
The pump should be installed inside an enclosure. If you live in an area which has freezing temperatures, the pump and all plumbing need to be protected from freeze ups.
May 11, 2014 | Plumbing
When i turn the switch on the pump buzzes and wont start , then trips the breaker . Help .
Either the pump is seized or the motor start capacitor is open or blown. If you can spin the impeller with your finger it is most likely a start capacitor problem.
Aug 20, 2011 | Sta Rite 1 HP StaRite Pump 15" inout...
I have a Starite pump but one of the wires is broke. I don't know where it belongs.I believe it's set up for a 220 line but would like to know if it could be changed to 115
On the pump tag there is a schematic of the electrical. one for low voltage and on for high voltage. look at the high voltage. the A and B terminals or for the wires in the motor. the lines in are for the white and black wires coming in from your power source.connect the lines in to the suggested terminals and it will power up.
The Pool Tech
Jul 14, 2010 | Sta Rite Starite Duraglas Inground Pool...
I turned my starite pump on and it just hummed for about 5 seconds then cut off. What could be wrong?
Your pump motor or impeller is seized. Disassemble the pump housing and check the impeller to see if it spins freely. If not then check for debris, if impeller appears to be free of debris, then check the shaft seal and motor. If the shaft seal is leaking water, then the motor bearing is likely rusted and will need to be replaced. There are 2 bearings, replace them both along with the shaft seal
Apr 11, 2010 | Pentair STARITE PUMP HOUSING / TANK BODY
Capacitor wiring on a ao smith M#-C48L2N134B1.
contact A.O Smith they should be able to supply you with a schematic.
Oct 20, 2009 | Pool & Spa
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
