Question about SanDisk Sansa c150 MP3 Player
Sandisk Sansa c150 2 GB MP3
I switched my MP3 player from my dongs list to the radio, when i tried to switch back i get a message "pleas sync you player"???? I can't even turn off the player after this message appears. I have to take the battery out to turn it off. Can you help me "sync" my MP3 player?
  • 34 Answers
Can you reconnect it to your PC and try to drop a song or two on the unit?
Posted on Aug 07, 2007
SOURCE:
Sansa MP3 Model e280 has frozen with the message refresh data base on it. I have turned it off and turned it back on again but it the message won't clear. I have even let the battery run flat and then...
Check out my tip on your problem -->
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format <-- copy the address into anew window.
To reset your Sansa Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present. You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes. You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) . 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that... Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Feb 15, 2010 | SanDisk Sansa E280 MP3 Player
I have a 4 gb Sansa Clip. How do I switch back
You can go to the main menu on your player and select which one you want to use at a time. Here is a manual that describes everything you need: http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Page 6-7 has the menu options/controls that you can use to do that.
Oct 31, 2009 | SanDisk Sansa Clip MP3 Player
How do i download music to it
use windows media player to load your mp3 player, open up windows media player and connect your mp3 player then once it recognizez it open up the music library and start dragging the songs you want from the list over to the sync list and after your done click on the sync button and wait after its done you should have hours of music to enjoy
hope this helps
Sep 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa SanDisk syncs, but doesn't display
i have unknowingly deleted my sandisk drivers, so again when i connect it to my system i see no usb-port connected, but player displays on the main display containing "san disk" how do i get my player in proper condition
Aug 12, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Doesn't want to syncronize music anymore
Get the recovery tool from Sandisk Support downloads. Put it in a file you can easily find.
plug in the Sansa, once it turns on, hold the power button until it turns off then switch the hold switch at the top edge of the player to hold (showing orange) and then hold the "Record" button on the side until the player turns on with a black screen, saying it is in recovery mode.
Some people have said they had to hold both "Power" and "Record" to make it work.
Run the recovery tool software and you should be running again.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
Cant switch to MSC on sansa e260
Try this instead:
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 21, 2008 | SanDisk Sansa e260 MP3 Player
My PC and my MP3 Player aren't speaking to each other!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 16, 2008 | SanDisk Sansa m240 MP3 Player
I can't put songs on my Sansa Sandisk e250....
Auto sync is engaged- switch to manual synce
Make sure your msuic svc subscription is current
Nov 25, 2007 | SanDisk Sansa e250 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
