Question about Plumbing
Neostrahl nd taps
Hot water tap leaks and handle seems to open up of its own accord even after closing off tightly. How do I best replace the washer
keemo68
  • 1263 Answers
SOURCE: Leaking Kitchen Tap
yes your right it's the seal inside and it can be replaced you should shut the water off after all why make a mess when you don't have to. however I'm not familiar with this typ of faucet. you more than likely be able to get help from your local area hardware store when you purchase your gasket for replacement.
Posted on Sep 02, 2008
SOURCE: dishwasher tap off
We've always left ours on until the wash was complete as there are a few times throughout the cycle that need water.
Posted on Sep 12, 2008
  • 148 Answers
SOURCE: Bathroom sink ''mixer tap'' leaking internaly.
if your valve is single handle there is usually a small
button type of cover for (sometimes rubber the size of a pencil erasure) that covers acces to a hex key screw that you have to remove to remove the handle
once you have removed the handle you will need a large adjustable wrench to turn a large nut that holds the cartridege tighten if still leaks remove and replace you can math the assembly at HD or Lowes
Posted on Dec 30, 2008
  • 148 Answers
SOURCE: leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
  • 35 Answers
SOURCE: Cold water tap not working, house heating not as strong.
Okay let's trouble shoot this problem. The Hot water issue may just be that your Temp. control is not set as high as it was before it was replaced. Find the control on the water heater and check the setting. You can adjust it hotter from there, but it is not recomended to set it all the way to HOT. Just increase it at small adjustments and see if the water gets hotter. The Cold Water Tap issue.....Turn off the Cold and Hot water supply lines to the faucet. Remove the Cold water tap. VERY SLOWLY TURN ON THE COLD WATER SUPPLY and see if you get water coming out of the line. If you get water, then your line is okay. Inspect the valve to see if there is any debris in or on it. Clean and reinstall both taps and turn back on the water. It should work. Now if you turn the water on SLOWLY when the Cold water tap is removed, and no water comes out, Then you know you have an issue with the line going to the cold water side. (Frozen Line, Debris in supply line valve, Broken or Leaking Water Line) I hope this assists you........Joe
Posted on Jan 16, 2009
How do i put the o rings and springs in my old leaking 2 handle faucet
Make sure the water to the tap set is turned off. Remove the hot plug button, use a small knife to pry it out of the top of handle. Remove the screw inside the handle that holds the handle to the cartridge. Use an adjustable wrench to unscrew the tap handle from the base. Once removed, separate the cartridge from the shell (the unscrew from each other). Use the appropriate size and type of screw driver to remove the screw holding in the flat washer. Using a small dull needle or flat screwdriver remove the "O" ring from the valve stem Replace the o ring by just slipping it on. Make sure you clean all areas of the stem and the stem cartridge of old grease and dirt etc. Use new clean valve stem grease on the O ring before re installing into the cartridge. Insert the new washer onto bottom of valve stem, Screw on. While you have it apart look down inside the tap to inspect the valve seat. If its chipped, broken, rusted etc you MUST replace it, if you do not any new parts will sot stop the leak. Valve seat MUST be nice and flat and clean. To remove the seats most taps will require a 3/8" Allan wrench. Push the wrench into the slot of the seat, turn C-Cw to remove, CW to replace. These parts are cheap. If you need to replace the seat, take it with you to H Depot so they can give you the correct one. NOTE: Its best to do the cold at the same time, saves you the trouble of doing it again later. Same applies to the cartridges. You can replace the entire cartridge instead of rebuilding them at only a few bucks each, its much faster and easier.
Aug 10, 2014 | American Standard Plumbing
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
Leaking kitchen tap
It is very easy to stop it just make sure you lock the tap and loose the tap head from the pipe then you get what they call white thread for taps just rap the thread round the tap and you just fix it back
Feb 05, 2014 | Home
All the faucets except my shower have hot water why doesn't my shower have hot water
your video doesn't show much of your shower for very long, but at a guess i'd say you have separate hot cold taps, in which case always turn on hot first then carefully turn on cold to ensure there's no issue with water pressure. if there no hot water running at all the hot water valve is faulty
Feb 07, 2013 | Home
Dripping faucet
first step would be to change the rubber washer or o ring.
  1. buy a proprietary washer kit from any DIY store.
  2. Turn water off at isolating valve on teh pipe underneath the sink / bath or at the mains and or hot water tank as appropriate
  3. Remove the top of the faucet (often there is a plastic circle at the top that prises off to reveal a screw - mixer taps may have a grub screw on the side)
  4. Gently using a wrench to loosen the nut unscrew and remove the tap (faucet) barrell (middle bit)
  5. Remove nut that holds washer in place and remove it or, in the case of an O ring - prise it off with a pin or needle.
  6. Reassemble in reverse order - do not over-tighten.
If that doesn't stop the drip then the seat that the rubber washer / O ring seals against may be pitted or grooved. Either buy or hire a 'tap (faucet) seating tool.
  1. Turn off water before opening the faucet
  2. dismantle faucet as above
  3. Find which of the sleeve adapters that comes with the seating tool is teh right one to screw into the top of the faucet body
  4. select the grinding disc that is closest to the size of the seat and screw it onto the end of the seating tool
  5. Screw the tool into place in the top of the faucet body - just finger tight.
  6. Pressing down firmly with even pressure (but not too hard) on the top of the seating tool rotate the handle backwards and three or four complete rotations.
  7. reassemble the faucet but DO NOT close the faucet off
  8. slowly turn the water back on and allow it to flow hard for a few seconds to flush and debris out of the spout
  9. Slowly close the faucet and check for leaks.
  10. If necessary repeat re-seating process
Feb 27, 2011 | Home
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
I have hot water coming out of house taps but not from out of the shower, we do not have a bath tub. there seems to be no obvious leaks. HELP! what can i do i have 4 stinky kids that badly need a shower
The tap fitting on the shower may have failed. Some of the modern fittings have a more complicated internal mechanism than the traditional taps and can fail rendering the tap inoperable. Turn off the water at the mains. First take off the tap handle and then with a spanner carefully unwind the tap spindle. Be very carefull not to use excessive force in case you damage the pipework behind. If it does not come ralatively easily leave it for someone else. When you have this out have someone crack the main valve and you should have hot water coming out. If the fitting itself is the problem you may be able to take the spindle and washer out of a standard brass garden tap and use it as a temporary fix untill you get a propper replacement. Just another thought, you may have an isolation valve on the hot water line to the bathroom. Could a kid have turned it off?
Aug 30, 2009 | Rheem Tankless Hot Water Heater...
Taps that connect to washer water hoses are leaking
first of all make sure water water is shut off to washer,you can take the handels off take the nut off that holds the valve in place there you find either a rubber groumet or o ring replace that put back together should fix your problem.
Jun 20, 2009 | Estate TAWX700JQ Top Load Washer
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Plumbing Logo
170 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
