Question about Sanyo Xacti VPC CG20 Video Camera
Where is the reset button - Sanyo Xacti VPC CG20 Video Camera
MX300 waste ink full
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
4) When the Power LED lights in green (and "ServiceMode Idle" is displayed on the LCD), press the Stop/Reset button the specified number of time(s) according to the function listed in the table below, then press the ON/OFF button. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting mode
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s) according to the kind of ink absorber whose value should be reset to 0%.
Aug 13, 2014 | Canon PIXMA Office Equipment & Supplies
Reset canon printer MP500
The reset method for Canon Pixma MP500 All-In-One Photo Printer
1. Entering into Service Mode
  1. Start with printer connected to power cord (electric source)
  2. Press and hold STOP/RESET button.
  3. Press and hold POWER button.
  4. Release STOP/RESET button without releasing power button.
  5. Click STOP/RESET two times and then release power button.
2. Reset the Canon Pixma MP500 All-In-One Photo Printer
  • After the printer entering into service mode, prepare paper on the printer paper tray
  • Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  • Press Stop/reset button for 2 times and then press power button, The printer will print again. Await till printer finished print again.
  • Press Stop/reset button for 3 times then press power button to reset EEPROM.
  • Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  • Switch off the printer. if printer doesn't turn off, press button power until printer off
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma mp 160 printer is not printing it just shows E & 5 altenately.Please solve the problem Jayaram
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
Aug 08, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Errer code 5
Aug 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Need to reset the Change Oil Light on a 2007 Mercury Grand Marquis
SWITCH IGNITION ON.ENGINE OFF. PRESS AND RELEASE SETUP BUTTON.PRESS SELECT TO BEGIN SYSTEM CHECK IS DISPLAYED. PRESS AND RELEASE SELECT BUTTON WHEN OIL LIFE PRESS RESET IF NEW OIL IS DISPLAYED PRESS AND HOLD RESET BUTTON FOR 2 SECONDS. OIL LIFE XXX% HOLD RESET IF NEW OIL IS DISPLAYED. PRESS AND HOLD RESET BUTTON FOR 3 SECONDS UNTIL OIL LIFE START VALUE SET TO 100 % IS DISPLAYED. SWITCH OFF IGNITION.------- NOTE THE SETUP BUTTON AND SELECT BUTTON ON STEERING WHEEL CONTROL PAD THE RESET BUTTON IS ON DASH THERE IS FOUR LITTLE BUTTONS ON DASH SECOND BUTTON IS THE RESET BUTTON.
Jun 05, 2011 | Mercury Grand Marquis Cars & Trucks
How to reset Canon mf4150
Hello and welcome to FixYa!
The manual reset Method for
Canon image CLASS MF4150 All-In-One Laser Printer is given below, Follow every step carefully:
  • Press and hold STOP/RESET button.
  • Press and hold POWER button.
  • Release STOP/RESET button without releasing power button.
  • Click STOP/RESET two times and then release power button.
Now your printer enter into service mode. Now
  1. Prepare paper on the paper tray
  2. Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  3. Press Stop/reset button for 2 times and then press power button, await till printer finished print again.
  4. Press Stop/reset button for 3 times then press power button to reset EEPROM.
  5. Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  6. Switch off the printer. if printer doesn't turn off, press button power until printer off.
You have done it
If any Further assistance required, I am here to help
I hope this solution helps you.
Your token of appreciation in the form of Rating as FOUR THUMBS (given below to this solution) and testimonial will be esteemed.
Thank you for Using FixYa
Apr 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
How can i reset my canon mp500?
The manual reset Method for CANON MP500 is given below, Follow every step carefully
You have done it
If any Further assistance required, I am here to help,
Your token of appreciation in the form of Rating as FOUR THUMBS (given below to this solution) will be esteemed.
THANKS and Keep Visiting FixYa
Mar 31, 2011 | Canon Pixma MP500 All-In-One InkJet...
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
Jan 11, 2010 | D-Link Computers & Internet
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
It says reset filter
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Dec 04, 2008 | Office Equipment & Supplies
Open Questions:
See all Sanyo Xacti VPC CG20 Video Camera Questions
Sanyo Xacti VPC CG20 Video Camera Logo
27 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
