Question about Cub Cadet Garden
Cub cadet rzt 54 rh transmission
Lh transmission works fine, rh wont do anything, sounds like its bogging down. wheel is locked, stays locked with bypass lever pulled
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 109 Answers
SOURCE: Cub cadet 2145 (Onan engine)runs the battery down
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
SOURCE: Cub Cadet RZT 50 Deck cable snapped
get a new one ours did the same thing its two boults
Posted on May 25, 2010
  • 146 Answers
SOURCE: I have a cub cadet RZT 54 that was purchased in
Do you hear a "clunk" when you engage the PTO switch, but the blades don't turn? If so, then check the mower deck belt - is it properly threaded, and tensioned by the idler pulley? If there's absolutely no sound when you engage the PTO switch, the problem is likely electrical (even though everything looks OK). The PTO switch, PTO clutch, and the reverse lockout switches (near the bottom of the fwd/reverse control arms) should be checked. I don't think there's a separate fuse for the PTO on your mower, but there may be a relay. Even though these parts and connections look OK, they can fail internally. Best bet is to get a multitester and check each of them with the ohmmeter function.
Posted on Jul 03, 2010
Cub Cadet RT 65 rototiller wheels aren't engaging
It's possible you have snapped the shear pin in the transmission shaft.
Jan 25, 2018 | Cub Cadet Garden
Cub cadet rzt s50 just barely moves when I step on reverse pedal
If fine in forward then you have a transmission issue.
Sep 06, 2017 | Cub Cadet Garden
Is there a certain way the blades should be when replacing belt on rzt 54 cub cadet mower
If I understand your question. No, the spindles are not timed. This is if you mean where they go as far as rotation.
Apr 11, 2014 | Cub Cadet 42 And 54 Inch Blade Operator's...
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Jun 01, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
