Question about Cub Cadet I1042 42" 18HP Zero Turn Tractor - ZTT42
Lack of power
My 4.5 yr old i1042 will barely make it up an incline and almost stops when doing a 180 degree turn. What happened to my power??? Thanks!
I had the same problem with my 2011 i1042. Turned out to be drive belt not snug enough. Installed new drive belt all OK now - plenty of power & speed, no slipping. good luck. (BTW: it was a REAL PAIN to remove and replace the belt!)
Posted on Jun 10, 2013
My washer stopped. I let It cool down. turned on power I hear buzzing for 3-4 seconds then stops. Is motor burned out?
Sounds like the electrical motor has seized up or the brushes in the motor have worn. Try removing the brushes if you can and turn them 180 degrees and replacing them that way. Best of luck!
Sep 25, 2014 | Garden
How tight do lifters need to be in a 1988 honda dx
.008" intake, .010"exhaust, turn engine to tdc #1 compression, adjust #1 cyl rocker arms, turn crankshaft 180 degrees and adjust #3 cyl rocker arms, rotate another 180 degrees & adjust #4, than another 180 to adjust #2.
Mar 30, 2014 | Cars & Trucks
Cub cadet lawn tractor
MOST likely cause is a worn/failed drive belt. I'd replace that first - be SURE to use a Kevlar belt or you'll be repeating the repair in a very short time frame.
Jul 15, 2013 | Cub Cadet Garden
Reset timing
A little odd. Here's how to find TDC of the compression stroke: Pull #1 plug out, use a socket on crank pulley and turn clockwise with your finger over plug hole. As crank nears 0 degrees on compression stroke, you can feel the pressure build up under your finger. You wont feel any pressure on the exhaust stroke as crank approaches and passes the zero degrees mark. Keep turning one revolution till you are on the compression stroke-you will definitely feel the pressure build up. Stop at 0 degrees-Now the rotor SHOULD be pointing to number one spark plug tower. Good luck.
Jan 16, 2012 | Toyota Cars & Trucks
When I turn it off all the dash lights come on the door dinger will not work the tail gate will not open and the dome lights will not come on.But everything works fine after you start the car.
I have the same problem I'm reading that its some type of wiring issue bare wire in the main harness you need to chase. The person befor me took the #3 fuse shipping fuse the only fuse with a black bracket around it and turned it 180 degrees this makes you losse the memory but your lights turn off etc...
Apr 07, 2011 | 2004 Chrysler Pacifica
The scooter charges and shows full charge when started. Scooter will not drive uphill - certainly seems to lack torque - when driving up hill battery indicator drops to red
Either the hill is too steep of a grade/incline, the weight of the rider is more than the scooter is designed to carry, or the battery does not have enough power. If the batteries are old or have not been maintained properly, they may not be getting a deep solid charge that is needed to operate on hilly terrain. This is indicated when the batteries show a full charge, and then drop off quickly after a short period of use. Make sure that you are not exceeding the recommended weight limit for the scooter and that your batteries are less than 2 years old. Inclines of more than 5-6 degrees are typically not recommended for safe operation.
I hope this information is helpful to you, good luck!
Dec 27, 2010 | Electric Strider Mini 4 Wheel Mobility...
LX90 Dec pointing out by 4 degrees over run
Go onto www.cloudynights.com and post this in the LX member forum-- and or go on YAHOO groups and post this in the LX90 forum--
Are you absolutely sure that your TIME and DATE and DAYLIGHT SAVINGS (yes-no) are correct.
On my LX90 the first alignment star is always NOT in the eyepiece but everything is OK once I center both alignment stars.
Feb 02, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Heater is not getting hot anymore!
Hi Phyllis, it sounds like your thermostat is stuck open, which results in the engine not being able to maintain operating temperature. This would explain the lack of heat. For your car to run at peak efficiency, u need to replace the thermostat, and enjoy having heat again!
Dec 09, 2008 | 2000 Pontiac Grand Prix
Our 4 yr old refridgerator & freezer quit working. power was on because the temp indicators showed 48 & 28 degrees. Should be 36 and 1 degree. We moved all of the food out and obviously temps...
These unit normally, if frost free model has a defrost cycle. It is possible that at the time you noticed it the system was in its defrost mode.
Jun 09, 2008 | Refrigerators
Cub Cadet I1042 42" 18HP Zero Turn Tractor - ZTT42 Logo
166 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
