Question about Transtherm Double Castel (Solid Door) Wine Cooler
Ice forming in wine cooler - Transtherm Double Castel (Solid Door) Wine Cooler
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
Ice build up
Normal to have a bit of ice. Set the temp to 0 for a few hours every week. Check Seal is good all round the door.
Apr 20, 2014 | Haier HVFM20ABB Wine Cooler
I always thought that light was bad for wine. Why is it that almost every wine cooler is look at has bright lights built inside?
The lights in a wine cooler are LED lights. These are safe forms of lighting to use as they will not raise the temperature of your wine.
Jul 31, 2012 | Furniture
My wine cooler is not reaching the set temperature. It stops at around 73 and the display flashed AL. Any ideas?
check to see if compressor cycles, if so you may have a thermistor problem which is intergrated with control, replace if you can find part. make sure to check evaporator, see if ice is forming if so you have a leak,or dry evap. you have a leak. repar.
hope this helps.
Aug 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Inside rear is icing up on Heir wine cooler
Surprised you don't get an "LL" error code for being too cold. Replace thermostat RF-7350-59 first, motor control next. Service manual out of print.
Mar 13, 2010 | Haier BC112G Wine Cooler
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
Ice forming inside of wine cooler
i would check running temp 1st/possible gas fault
Feb 17, 2009 | Avanti WC400YGB Wine Cooler
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
Jan 18, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
The fan to disperse air inside the STC55800 wine cooler is inoperable.
9721, Boul Métropolitain Est
Anjou, QC, Canada
H1J 3C1
Telephone : 514-374-5343
Fax : 514-374-5344
Oct 04, 2008 | The Cellar STC55800 / STC55810 / STC55820...
Transtherm Double Castel (Solid Door) Wine Cooler Logo
Top Transtherm Refrigerators Experts
Andrew Taylor
Andrew Taylor
deton8 von Splosion
scott williams
scott williams
Level 1 Expert
Are you a Transtherm Refrigerator Expert? Answer questions, earn points and help others
