No wifi Gateway laptop not recognizing any wifi connections. Had difficulty starting it up this morning, it would click on and off over and over again. I removed the battery and put it back in, then after clicking on and of a few more times it finally came on. But now it doesn't detect any wifi connections.
    Scholar:
  • 156 Answers
Reinstall the WiFi adapter driver from Gateway support website.
Restart the notebook . Hope this helps
Posted on Apr 26, 2013
Pyrhyc
  • 2028 Answers
SOURCE: Laptop will not turn on
The two most common causes fot this on the IBM machines are the battery and the memory. Start be removing the battery and starting with the power supply only. Then remove the memory and try each chip one at a time in each slot. If these don't work, then I'm afraid a component has failed in the power management system on the motherboard. Failed power management systems are also common with these, but not as common as a battery or memory failure. If it's the power management system, unfortunately, the motherboard will need replaced.
Posted on Sep 01, 2008
  • 916 Answers
SOURCE: laptop got stucked up when connected thru network cable
I have had problems myself with wifi and vista causing my laptop to restart I think it's due to a recent update, try using no security on your wifi connection and see if you get the same problem. On my own laptop I had to remove the wap key and use mac address filtering instead due to this problem. Please let me know the results.
Posted on Feb 03, 2009
SOURCE: Pavilion TX1000 - WiFi card suddenly not detected
The solution is, get a USB wifi adapter, because that card is done. HP REFUSES to recognize this problem, and since the majority of failures happen after the warranty expires (mine did) HP just says you are SOL. You can get decent wireless adapters for $20, and your wireless problems will be solved. Unfortunately, expect your laptops motherboard/chipset/dc port to fail within a year :(
Posted on Apr 20, 2009
durtopian
  • 408 Answers
SOURCE: Asus U52F laptop -- 1
Sounds like a faulty wireless card or the card is installed with the wrong version driver.The wireless card itself sounds to be bad and needs replacing
Posted on Jan 11, 2011
Kyocera milano 5121 recognizes and remembers my att uverse gateway, but switches to disabled within a few moments.
Click on your wifi connection and have it forget the uverse connection, and then turn wifi off.. Then reboot your phone. When it comes back up, turn wifi on, search for your uverse connection, put in your password, and see if that fixes it. Sometimes the connection becomes corrupted.
Semper Fi,
Z
Jun 03, 2017 | Televison & Video
How do i enable my wifi adapter on my samsung NP365E5C laptop? it's not recognizing wifi.
click on your internet access icon and check it has not turnd of,if so just turn it back on.
Apr 17, 2014 | Samsung 15.6" Laptop Computer -...
Acer Aspire 4339 issue with home network connection
are you internet drivers installed?
try to connect your gateway first to know that your connected to your device
simply press start then type cmd (command prompt)
type ipconfig and you will see the DEFAULT GATEWAY then type that on yor web browser if you can connect ....
also try troubleshooting your adapter..........
open network and sharing center then go to the "change adapter settings" in the left pane then right click your adapter and select troubleshoot this
windows can find the problem and it can fix automatically
Nov 28, 2013 | Acer Aspire 4250 4251 4252 4253 4333 4339...
NV55C Gateway Lap Top cannot connect to wireless router
Does your WiFi work on the laptop work in another place... Starbucks for example? If so, then there is a software security issue with the router, you will need to call the ISP for adjust the settings. If you PC doesn't work with wifi at Starbucks then you have a software issue with your laptop. Go to MY Computer, Hardware/Devices and look for any yellow marks. There will probably be one where the wifi is located. (Expand all the devices by clicking on the plus "+ signs. Find the wifi modem, there are many mfrs; Broadcom and Atheros are two ones. Go into the submenus and driver update too and write everything down you find. The most important things are the description, model number, software version and version date. Navigate to the hardware mfrs site and download and install the newest drivers for the wifi modem. Re-boot and try again to establish a connection.
Jan 23, 2012 | Gateway NV55C03u Laptop
Quick question regarding the Gateway Solo 9550 laptop. I cannot connect to any wifi network. The laptop recognizes networks by name, but it does not connect. Any ideas?
Try clearing your winsock///Click start...Go to run..type cmd....Then type netsh winsock reset. Computer will say need to reboot but not nessasary
Apr 04, 2010 | Gateway Solo 9550 Notebook
Cant find the wireless switch to turn on
Click start menu then look for ALL CONNECTIONS folder then click that portion and enable wireless connections after detecting there is wifi onsight.
Thanks.
Dec 12, 2009 | Gateway M460 Notebook
My wireless laptop gateway won't connect to my router again after going out of town using it at hotel and now it wont connect at home. it will connect on my job with no problem
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Feb 18, 2009 | Gateway MT3705 Notebook
My laptop will no longer connect to my wireless router but my desktop still has online service.
check your laptop wifi , are you sure that is on, search wifi , you must saw wifi ap in your windows, so click connect with wifi that is choose, if your set is in automatic ip gateway and dns server , you must take on your dhcp mode in your router, if itsn set your ip in permanen value
Sep 26, 2008 | Gateway Computers & Internet
WiFi not recognized on Compaq laptop
this can happen sometimes, just go to network connections in control panel, right click on the wireless icon and click dissable (or press the rellevant button on your notebook) Restart pc and then right click on the icon again and select enable. There should be an icon in your taskbar, right click and select view network connections, and then see if your router is listed and click connect.
Sep 25, 2007 | NetGear WGU624 Router
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
