Question about Whirlpool GHW9300 Duet Washer
Diagnostic test How to get washer into diagnostic mode
F1 code pops up and the washer stops. Lid won't come unlocked.
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%@#$$
Aug 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer model # wtw64005w0 starts to fill stops and and F1 shows up
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does a f1 mean on a whirlpool cabrio washer?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%#
Jul 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer was flashing f1 whirlpool had A&E come to fix it now its flashing LF and the washer is just humming
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#%
Jul 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer shuts down showing F1. after 4 or 5 tries washer continues to work but clothes are very clean
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#$
Jun 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does f1 mean on a cabrio washer
Apr 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer comes up with f1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(@#$%
Apr 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washer flashes acode f1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#%^
Mar 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code f1/f2 --washer turns off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*$%^
Mar 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When washer starts get F1 error
Nov 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
