Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Blinking As soon as i plug my monitor to thewall the LED turns green, but themonitor in blinking and it says auto image adjust, and I Don't Know What To Do
  • Martin Crespo Aug 08, 2007
    the problem does not have to do with the computer nor the video card the problem is the monitor, because its always off and turns on every second, maybe i wasnt clear enough, but when it turns on the LED from the monitor and the one from the power box, i was thinknig, that the power box might be the problem because is not turned on completly
    Brigadier General:
  • 6,966 Answers
Hi, You may want to try lowering down the screen resolution of your display properties of your PC. If you can't set it properly or the monitor will not allow you to do so, try restarting in safe mode (press F8 when booting). Pls post again how things work up so we will know if this did the trick or we have to come up with something else. Good luck and kind regards.
Posted on Aug 06, 2007
SOURCE:
Samsung 710v problem. It started out as "Not optimum mode" for which i applied the 50/47 ohm fix present around the web. It worked for around a year.
Not optimum mode refers to the resolution. If you set it to 2048x1024 and your monitor won't support that, it will give you this message. Remove the resistor. In Windows Control Panel go to display. Adjust your resolution to your preference in the table. Do NOT exceed the table. You may have fried your monitor with the resistor. Good luck.
Nov 04, 2014 | Computers & Internet
Black screen and a blinking green led..
Have you tried booting the machine into safe mode? turn off the pc and try inserting a rescue boot disc to see if it will go that route.
Aug 27, 2009 | Samsung SyncMaster 244T Monitor
Switch led is continously blinking in green colour
Sounds like you don't have a stable connection. Try shutting down PC, and disconnect the monitor, and reconnect it, and turn PC back on, then turn the monitor on...
May 14, 2009 | Hitachi CM621F (White) 17 in.CRT...
Screen won't turn on
only the touch not works but the monitor is good
Mar 16, 2009 | 3M MicroTouch M150 (Black) LCD Monitor
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 710N
hi, try with another crt monitor to check if the display card is ok..if that works fine then u will have to take it to the service center.. let me know..
Jan 10, 2008 | Samsung 710N V2 17" LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
779 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
