Question about Welch Allyn CP-100 Resting ECG / EKG
Machine My unit is printing the aVR result ONLY upside down.
  • 15,557 Answers
This has to do with where on the body the positive electrode is placed..in aVR the positive is on/near the right leg...a positive deflection, upright wave, is seen if the electrical activity, heart depolarization, is traveling towards the positive electrode...since the heart is rotated towards the left in the chest, normally electrical activity trends left...so in lead aVR the electrical activity is traveling away from the right so it gives a downward deflection of the waves
Posted on May 18, 2013
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
Hi how do you print double sided please
This printer does not have a duplex unit and cannot print double sided prints automatically.
The only way to print double sided is to print page 1 and the insert the page back into the printer tray with the page upside down and then print page 2. Repeat this for the other pages.
You need to do a test print first to work out which way to insert the page upside down in the printer paper tray so the printed text is aligned correctly on both sides of the page.
Nov 29, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I just purchased a used Denon AVR-3200 and have nothing hooked up yet but plugged it in on my kitchen counter and upon turning the unit on, noticed the error overload button was lit up but the unit did not...
Hi
I've had an AVR 3200 for about 10 years - occasionally (maybe once every 6 months), the error overload button comes on... for no real reason than i can detect (ghosts in the machine, maybe)... rebooting has always fixed it for me.
Aug 21, 2010 | Denon AVR-3200 Receiver
No ink on paper with printout, alignment or clean cartridge.
paper is either upside down or you have a bad ccd or you have a bad main board
reset the machine... copy and then print
flip paper upside down and copy then print
check fuser if it is cold after print... if it is cold then bad fuser... if it is warm then bad main board or ccd
if you get printouts but no copies bad ccd
if you cann't get copies and no printouts after all these tests then bad printboard or main board
Dec 03, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
My AVR 235 stays on stand by
Hi...
That sounds like a amplifier module /section that has failed.
Do you ever get power surges at your place?
Oct 05, 2008 | Harman Kardon AVR 235 Receiver
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Aug 18, 2007 | HP Photosmart 3310 Printer
Problem with charging lead(s)
You will have to send it to a service support centre to get the connector repaired.You can buy it for approx £17 or send it to the centre for repair.it is a common fault with this machine.the connector is soldered on to the printed circuit so unless you are confident in repairing it i would pay the extra and give it to someone who knows what they are doing
Jun 21, 2007 | Mitac Mio 168 Pocket PC
Welch Allyn CP-100 Resting ECG / EKG  Logo
117 people viewed this question
Top Welch Allyn Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Welch Allyn Medical Expert? Answer questions, earn points and help others
