Pioneer tv model SD-P50A5-K
TV CLICKS ON THEN RIGHT OFF. NO CHANCE FOR PICTURE OR SOUND
    Top Expert:
  • Televison & ... Master
  • 75,452 Answers
There should be two relay clicks, if the set is perfect. It it clicks once and goes off, there should be some short circuit inside its circuit. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Posted on Apr 26, 2013
5 Suggested Answers
  • 1030 Answers
SOURCE: convergence ic's
difficult.. if you have no solder experence ...dont try it.. depending on your exp..ok.. as a tech thats a everyday thing.. they are two big black ic mounted on big heat sinks...with a bout 20 pins that can be difficult to get lined up. When you replaced them however ..there is a few other things to check. fuses. and output resistors. just getting the boards out can be difficult.
Posted on Dec 10, 2007
Slinteriors
  • 8617 Answers
SOURCE: pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
Posted on May 28, 2008
  • 1550 Answers
SOURCE: Pioneer SD-P50A5-K 50 inI
1 With tv off/in standby....press home menu.
2 Within 3 sec turn tv on , Integrated Menu will appear.
3 Hold Display button until Final Setup appears in the top menu.
4 Arrow left or right until yes appears in lower menu.
5 Hold enter until menu disappears.
6 Wait 1 min.
7 Power tv off and unplug from the wall for 5 or more min.
Posted on Nov 04, 2008
SOURCE: Can this TV be used
Yes, assuming you are using the included composite video / stereo audio cable with RCA jacks. The output would be 480i and the set would handle it the same as it would any other signal at the same resolution and refresh rate. If you mean damage to the front of the screen because of losing control of a remote, then it doesn't matter what model of TV you use. :p
Posted on Mar 20, 2009
I turn my TV off everything was ok..then I turned it back on but no picture sound only ,,,why ?
you might try do a hard reset. turn tv off unplug it hold power button on tv for bout 30 sec. then plug it back in. i had a similar problem and this worked for me.
Oct 08, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Can this TV be used with Nintendo WII video games without damage to the screen? 1997 pioneer SD-P50A5-K
Jan 29, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
My grand daughter had the remote. did something no sound nor .
try unplugging the t.v. this usually resets them to factory settings
Nov 15, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
Nov 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer projection TV vertical lines on screen
do you have full picture and did this set have any faults before this,possible image burn on crts.from previous horizontal fault.
Aug 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer sd -p 5191 tv
mrman: It is a great chance Jeff that your Power Supply Board (specially the FlyBack) could not hold the voltage requirement to let your TV set on. If you love your TV set, I'll suggest to keep it and repair it. Probably you would have to replace the FlyBack and then check out if the TV stays on. This will cost you from $75.00 to $95.00, but it will not guarantee that it will stay on. I really suggest you to replace the main power board (from $175.00 to $250.00 - with core exchange). It is something you can do on your own and I'll recommend you to check on the following site (my favorite to buy parts, service is also ok): http://www.vancebaldwin.com/ SithPitt
Jun 27, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
