Where do I find power board PK101V1080I
Our Toshiba LCD TV is not powering on and a friend suggested we replace the power board in it. The label on it says "PK101V1080I". Where can I buy this board or can I somehow repair it?
    President:
  • 749 Answers
circuitworld
  • 335 Answers
SOURCE: LCD tv main/digital board
Send it to us and we will refurbish the board.....
e-mail me....circuitworld@comcast.net
Posted on Feb 11, 2009
SOURCE: samsung lcd tv keeps clicking but won't turn on
ur tv needs a new ip board u can remove the back panel and its the center main board it'll be obvious to plain site being its the only unprotected board in the tv. get the model number from the top left of the part then go to samsungparts.com enter the part number order the part.this part is only about $130-$150 dollars and ur tv should be as good as new. the ip board is a simple fix just six screws around the board and seven wireharnesses just remove insert new part and and reconnect wire harnesses to correct slot that u removed them from screw back down and ur all set no big deal. dont ask samsung or a repair man they'll just screw u over and throw u around about ten differetn loops. not gettn a straight answer other then bring it n and charge u about $600 to fix. i see alot of people have this problem so there u go simple fix guaranteed. u r welcome.
Posted on Jun 13, 2009
SOURCE: dellw2607c no power
there is no fuse in these tv's i wish this person would look more closely it has something to do with the main board on the 2607C Dell LCD's
Posted on Dec 28, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
Vizio 55 inch TV "Vizio E550I-B2" is Darker on the left viewing side, replaced the Power Supply board. And the Screen is still dark on the left side. Any suggestions?
It is a common problem for this TV, it uses a Sharp LED display panel. The problem is the data buffer IC inside the panel ether shorted, or burned open.
Vizio offers a extended exchange warranty if you have the original sale slip.
For more information, you may contact Vizio directly.
Apr 24, 2017 | Vizio Televison & Video
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
Is it ok to turn a Toshiba LCD TV off at the power point to save a little electricity? We have a circuit breaker adapter board which runs 5 red LED's at night (TV, DVD player, sterio, surround sound...
Yes its fine to turn the power off at the power point. In fact this saves money because there is no idle appliance power drain. It is also a safe practice to disconnect the power at night or over longer periods of inactivity because there have been instances where plasmas in particular have caught on fire. Turning the power off will not affect your friends LCD TV they are designed and built by engineers who incorporate power surge protection. The circuit breaker should be one of very good quality and if this is the case then your friends LCD will be fine.
Jul 12, 2011 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
Toshiba 32av502r lcd tv keeps turning on & off, will not stay on. screen is black, but the power light keeps blinking.
The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Nov 21, 2010 | Toshiba 32AV502R LCD TV
Toshiba LCD TV 32XV555D will not turn on via full power down button or any other means.
The power supply board is dead.That the power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 07, 2010 | Toshiba 32XV555DB 32 in. LCD TV
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
TV wont turn on--power light blinks but no picture
The problem is in the power suplly board.In the LCD TV this board is common to the rest function.If the reparation cost is 80% on the new LCD I suggest to buy one new.
Sep 01, 2009 | Toshiba 23HLV87 23 in. LCD Television
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Electro Med Services...
