Question about Tomtom GO 300 GPS Receiver
Sometimes comes on. most times doesn't come on
Hit the on button, nothing happens. Plug in the unit. will power up. shut it down. try to power it up. nothing happens. how do i split the case? do i need new batteries?
  • les temple Aug 07, 2007
    thanks for all the help skipper360. but how do i split the case on these bad boys? I'm pretty sure i can replace the battery if i can split the case. help please.
  • 58 Answers
You need a new Battery. You said if you powered up on the plug its working right? So try to charge the battery like 30mins or so then try to power on to battery. If not get a new batt.
Posted on Aug 06, 2007
SOURCE:
Why doesn't my laptop start?.
remove the battery for about a 5 minute then insert it again, then press the on button
Jun 03, 2014 | Computers & Internet
Sharp tv shut down after about 2 seconds
Could be power supply trouble. It tries to start but can't and shuts down.
Dec 06, 2013 | Televison & Video
I have a Lenovo Y510 that will NOT shut off or do anything it is completely frozen .. I tried to hit ctrl alt delete all at once nothing happened still frozen any suggestions???
Try holding the power button down for several seconds. Or disconnect the power (pull the plug or remove battery). When you turn it back on, it will probably tell you that you didn't shut it down properly and hopefully you've saved whatever you were working on.
Sep 24, 2013 | Lenovo ThinkPad X61s Notebook
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
I have a rca truflat tv and when I plug it in the standby red light comes on but nothing happens when I hit the power button. I have tried holding down the ch- and vol- buttons at the same time and nothing...
I work on a lot of this model RCA, a reputable tv shop can repair this type of problem for less than a new set. You really need a techician for component level repair of this nature.
Jun 17, 2010 | Televison & Video
My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
Dec 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
I cant get it to even turn on
remove battery and use it off A/C power adapter, mine only works this way, maybe shorted battery.
Jun 28, 2007 | iRiver PMC-120 Digital Media Player
Sony ccd-trv68
Unit has circuit problems, have serviced
Apr 18, 2007 | Sony Handycam CCD-TRV68 Camcorder
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Tomtom GO 300 GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
