Question about Lands Phones
Rca line phone model 25423 24
I have three new phones for a small business...all utilizing the same one phone number. When I unplug all of the old phones and plug in the new ones I do not get a dial tone nor do anything of them auto assign an ID. The menu button also will not function to assign them. The intercom button is blinking red/blue and the display screen shows "Phone Set Up" and plug line 1 and below that plug all other lines. Suggestions?
SOURCE: Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
Posted on Feb 24, 2008
  • 3 Answers
SOURCE: My intercom button flashed red to green.
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Posted on Jul 26, 2008
cnavarro
  • 2460 Answers
SOURCE: PLEASE, PLEASE try and help
Just in case you missed the manual:
http://www.centralcomms.co.nz/pdf/KX-T2375-brosh.pdf
There are 2 conditions you need to be aware of
1 No DSL on the line
2. Set the intercom extension of the second phone
By default, both have been assigned ext 11. The intercom uses the same frequencies as a DSL line to transmit, so that could be the noise you are hearing.
Page 23 tells you how to set the intercom extension, and the DSL warning is almost at the bottom of every page from 18-22.
Carl
Posted on Nov 25, 2008
SOURCE: Intercom / page problem with AT&T phones model 944 and 955
I have the same setup in a small office I consult for and I found the intercom problem to be caused by the DSL filters. It seems the DSL filters also filter out the frequency that the phones use to communicate with each other. If any of the phones had a DSL filter on them the intercom and hold button would not work properly with the other phones in the system without filters. Once I took the filters off the intercom and Hold function worked fine.
Posted on May 05, 2010
greg411
  • 45 Answers
SOURCE: We are a small company and we use the RCA 4-line I...
The phone may have the same extension as another phone in the system. Unplug it from the power and take out the battery for a minute. Then plug it back in. It should take a moment to find other phones on the system and assign itself an extension number.
You may also have a line reversed on that phone. Check to see if line 1 is line 1 on all of the phones. Then line 2, 3 & 4.
Another thing to check is the DSL filter. That phone may need a filter on the line to keep your DSL from interferring. If it has one replace it.
Posted on Jun 02, 2010
The new message light keeps blinking and how do i delete or listen to messages
Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
Jul 27, 2011 | RCA 25413RE3 Corded Phone
Hello, we were having phone problem with our main phone and swapped it for a extra phone we had in storage. Same model. In doing that, we lost our caller ID on the main line to our business. When we...
According to the manual, the RCA 25413 does not support Caller ID. I have provided a link where you can download the manual. The manual is for model numbers 25413 and 25414. On page 8 it details how to turn caller ID on/off for each line under Ringer Tone heading item 6 Note, but the note says it does not apply for model 25413. Hope this helps.
http://www.rca4business.com/products/pc/pdf/instruction-book/25413RE3.pdf
Feb 24, 2011 | RCA 25413RE3 4-Line Corded Phone
We are a small company and we use the rca 4-line Intercom Speakerphones. Out of 4 phones one has the intercom button that continously flashing blue and red and the intercom does not work. The other 3...
May 21, 2010 | RCA 25423RE1 Phone
How do u work a rca office telephone
RCA & GEt offers a handy 4 line business phone that's perfect for most small businesses. Have up to 8 lines by stacking 2 sets of phones on your desk. It's easy to setup because it doesn't require any special phone control center or software. Just hook them up like any other 1 line or 2 line phones system and your business is ready to go. You'll have up to 8 phone lines with the ability to place calls on hold, transfer, conferencing, hands free speakerphone and much more
Aug 16, 2009 | RCA Lands Phones
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Pluged in my phone line and the phone reads Error
Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
Apr 09, 2009 | General Electric RCA-25424RE1 4-Line...
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
Sep 05, 2008 | RCA 25205RE1 Phone
New Message Light won't stop flashing
Jun 02, 2008 | RCA 25414RE3 Corded Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Message Indictator
hi its hard to understand... the phone is connected to line 4 or not? if so and line 4 is dedicated to fax line then the fax tone is the cause of your confusion fax tone is different from a regular tone phone if the phone isnt connected to line 4 and only to all 3 ordinary lines - then the phone is getting a over volage from them and activates the light & messege alert my advice let it be you will start playing with it something else will go worng... good day
Feb 19, 2006 | RCA 25414RE3 Corded Phone
Lands Phones Logo
100 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
