Question about Dell 1410X DLP projector 2700 ANSI lumens XGA (1024 x 768) 43 with 2 years Advanced Exchang Projector
The screen shows multiple tiny dots. (stars)
Even after replacing the lamp, I'm still seing multiple yellow / white spots (kind of like "stars") on the screen. Since the lamp was already failing I replaced it, but the problem continues. Any idea?
  • 25 Answers
Are they sharp and defined, or 'blob'-like? If they are sharp, that would indicate a faulty DLP block (not worth repairing, unless under-warranty.) If they're more 'blob'-like, it's probably just dust in the optical block. That can usually be remedied by removing the lamp, and blowing-out the unit with an air compressor. Canned air won't do the job, as there's not enough pressure.
Posted on May 01, 2013
  • 1 more comment
  • Luis Mercado May 02, 2013
    They look pretty defined and static, I mean not like if it is just dust. However I will proceed with the blow out just to check if there is an improvement. Thanks a lot for the solution. (Crossing my fingers) :-)
  • Kelly Boswell May 02, 2013
    Best of luck, but it sounds like a bad DLP block. :(
  • DiAnne Trail Sep 06, 2013
    So we have 5 projectors in our school doing that, do we throw them out?
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
The light shines yellow on the screen. Is it the lamp that's on its way out, or is it just a setting?
If the yellow area is mainly in the centre and not a well defined spot, then it's most likely the blue polariser plate that has been overheated by the white light over much use.
Sep 20, 2011 | Hitachi CP-SX5600W Multimedia Projector
My projector is showing multiple white dots, looks like lots of small stars all over the screen when projected to screens. is this mean I need to replace the lamp? TDP-XP1 model.
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
Oct 19, 2010 | Toshiba TDP-SP1 DLP Projector
InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
Jan 29, 2009 | InFocus LP 850 Multimedia Projector
Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
Jan 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Yellow Spot dead center on screen
Any color spot is never the lamp with this type of set.
the yellow spot is caused by the optic block (Engine). Very expensive to buy.
Little over $1000 plus labour with a qualified technician.
Sometimes technician may try to clean or repair inside but most likely won't succed.
good luck.
Sep 20, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony ps 2
Are you sure you have it hooked up to the tv properly? Maybe you accidently put a yellow in a white spot and a white in a yellow spot.
Mar 25, 2008 | Sony PlayStation 2 (PS2) Console
Dell 1410X  DLP projector  2700 ANSI lumens  XGA (1024 x 768)  43 with 2 years Advanced Exchang Projector Logo
310 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
