Question about Cell Phones
Help please How do i Check oil on motor
    Top Expert:
  • Cell Phones Master
  • 42,728 Answers
There is a dip stick screwed into a tube on the side of the crank case or a screw plug directly into the crank near the bottom (normally coloured red) If it is a screw plug then unscrew and correct oil level is near top of thread Replace plug when finished. If it is a dip stick remove the dip stick--- wipe clean ---and replace screwing it all the way I. Remove again and check oil position on dip stick Should be on top mark or top hole if there are holes.
Posted on Apr 26, 2013
I have a 2004 Toyota highlander leaking oil, oil light comes on. Could it be the rubber rings?
a 2004 toyota highlander V6
this should be your engine type
The 2GR-FE is a 3.5 L (3456 cc)
if leaks are that bad
always check the engine oil level before you drive off
fixing oil leaks on motors
degrease whole motor top and bottom
start with replacing the oil sender it may be the cause of the oil light coming on
after degrease
lay cardboard or paper under the car
take out for a drive and park over the paper over night
this pin points most of the oil leak locations
leaks from a V6 motor
rocker covers/ spark plug tube 0 rings.engine seals
cam seals
front and rear engine seals leak often
sump gasket can leak
if oil consumption or light on continues
can be a failing engine oil pump
or worn main bearings giving low oil pressure to the whole engine
you could be burning oil from worn piston rings
or hardened valve stems
a mechanic can fit an oil pressure gauge to the motor when hot
to check running oil pressure to confirm low oil pressure
if engine is worn out
it is possible to fit a lower mileage used motor to your highlander
its often cheaper than and engine rebuild
Oct 13, 2016 | Toyota Cars & Trucks
My Campbell hausfeld air compressor runs to 20 psi and then motor starts to bogg and then stops but motor still trying to run? Please help!
dont know size of unit ---if 220 check power in- under that will bog motor same with 110v --if using extension cords to long a feed from source and your voltage drops from resistance in wires ---motor may need service oil bearings --same with compressor motor oil change/needs oil added
Jul 12, 2016 | Campbell Hausfeld Air Tools & Compressors
Why is my car not starting after overheating?
The first thing to check is the oil. If there is no oil in the motor, the first thing you want to do is to get some witnesses, hopefully someone (s) who know how to check the oil level. Then have the same person looking under the motor to see if the oil drain plug (or bolt) is still installed on the oil pan. Remember NOT TO ADD NEW OIL to the motor if it has no oil.
If the motor has no oil, make sure you don't start nor drive the car. Contact the shop that supposedly replaced the oil, and make sure that your witnesses back-you up when you need them. Don't let the shop take your car and then tell you that the motor had oil in it.
If the motor has oil in it, then do some of the things other posters have told you to do.
Mar 22, 2016 | Cars & Trucks
Sc 558 error code on Ricoh Pro C720
SC558 is a Oil supply motor error The machine detects a motor rotation error for 5 seconds after the oil
supply motor has rotated for 5 seconds. ?? Oil supply motor defective
?? Oil supply unit defective
1. Replace the oil supply motor.
2. Replace the oil supply unit.
Jan 29, 2015 | Ricoh Office Equipment & Supplies
Pecking noise in or around motor & missing
get the engined serviced .check the oil level .
Mar 03, 2014 | 2002 Oldsmobile Silhouette
Murray tiller wont start
first check for spark if no spark check the oil some have a low oil shut off next try and spray some carb cleaner if it fires on that you may need to clean the carb
May 16, 2012 | Garden
Ticking noise in the motor when the motor is cold.
Please check your oil type and oil level. You may use wrong oil ( viscosity need to cross check with car make). Usually you can avoid this problem by using a higher viscosity of oil).
Regards
Feb 27, 2011 | 1996 GMC Sonoma
My mutsuibish shogun 1994 v6 keeps overheating and building up so much pressure that it keeps spliting the radiator hoses???????? PLEASE HELP
ur car is overheating because it does not have the capacity to dissipate high coolant temperature from ur engine to ur radiator or heat exchanger/ check auxilliary fan operation/ if electrically operated check fuse or motor condition/ if no motor check fans silicone oil/ could be too less/ check radiator condition it coul be blocked that why it restrict coolant flow/ check thermostatic valve condition could be stuck up and restrict coolant flow to the radiator...check coolant reservoir if water has oil in it/ if it has oil in it then ur engine cylinder head gasket is broken....
Apr 09, 2010 | 1987 Mitsubishi Passenger
Motor oil
change the oil pressure sending unit on the engine.
Mar 31, 2009 | 2000 BMW 3 Series
Service manual /equivalent oil requirement
I do believe that this motor running without any oil, i am not to familliar with this particular model, all the Tsurumi model that i know run with air ''magnet'' insulate motor,
Please check with our head office
www.tsurumiamerica.com
www.tsurumi-europe.com
Hope it help you
TsurumiMan
Everywhere Always
Dec 05, 2008 | Tsurumi Pump 2x25 Blk Pond Flex Hose
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
