Question about HP (178373133) (Refurbished) (178373133) CD-RW Burner
Not recognizing disc in D drive
OK...first off...I am a technical dummy. A nice guy, but a technical dummy. We are trying to rip/burn some audio books on her HP. It allows us to rip, but when we try to burn, we get a message saying it is not recognizing the media in the D: drive. One, we are using DVD-R discs (when I bought them, she said she had a dvd burner, which she does not. Can you burn audio onto these kind of discs? And if it can, why is it not recognizing it. I'm trying to do this through her Windows Media Center. Thanks in advance, Gary
  • HP Master
  • 12,061 Answers
Hi, well the short answer is NO. You cannot use DVD's in a CD Writer at all. So the simple answer is to get some CD-R and copy the files to them. OR get a Combo DVD/CD writer and install that as well.. and then you can use both..
Posted on Aug 06, 2007
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
I have a number of RiDiscs with 4.7GB of material ( lectures) that I want to download on smaller discs so that I can play on my car cd player. How do I accomplish this?
The easiest way:
check the item on the link below:
http://www.i-source-global.com/epages/170990.sf/?ObjectPath=/Shops/170990/Products/RFMP3SD2&ViewAction=ViewProductViaPortal&Locale=en_US
Copy your audio file from the disc to a USB (pen drive) I am assuming your files are in mp3 format. Else use the audio ripping software mentioned below to rip the audio file and save in mp3 format and copy that file into the pen drive/SD card.
Connect the transmitter to your cigarette lighter adapter. Turn your car radio on. Tune the FM channel to a frequency, where there is no radio channels. Note that frequency. There will be a + and minus button on the transmitter. Press it up or down to bring the transmitter to the noted frequency. You can now hear the audio through your radio.
Different options of this transmitter are available. Some use a SD card instead of USB drive. All cost around $25.00
The second method is to rip the audio files to your hard disc. Use any software. For an example,
Check the link below:
http://www.freerip.com/
Download and Install. If your cd player is capable of playing MP3 files, rip the audio files from your disc as mp3 files to your hard disk. copy them to regular cd's. (assuming you have a CD burning software)
If your cd player is not capable of playing mp3 files, rip them and save as .wav files.
Then you need a cd burning software.
Go to the link below:
http://alternativeto.net/desktop/k3b/?platform=windows
Download K3B. Install
Open it. Select, a new audio project.
Drag your .wav files into it. Burn it. and you are ready to go.
Feb 25, 2010 | Compaq Presario 5000 PC Desktop
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
CD drawer won't open or close or recognize blank disc
Not very likely to be overheating. CD's don't really have drivers & if it was working OK then a firmware upgrade isn't needed. Full drive won't cause the problem.
Pretty much the drive has just died. If the motor runs when you hit the door button but the tray doesn't move - try *gently* pushing the door closed. If it doesn't go - new drive.
If the motor doesn't run when you push the button, you can check to see if the power cable somehow came off but that's extremely unlikely. Most probably you'll just have to get a new drive.
If you've been in the habit of pushing the tray to start it closing, stop!! That's the most common cause of your kind of problem. ALWAYS open and close with the button.
Apr 22, 2009 | Toshiba Satellite A135-S4467 Notebook
Won't recognize an MP3 format CD
Usually a disc with audio files is not encoded with MP3's, but, rather, audio files. You can check this by manually opening the disc (right click on the player when the disc is in it), and looking at the files. If you only see marker (files of a few kilobits) in "MP3" format, then the disc needs to be "ripped" into MP3 format.
The ratio for audio to MP3 is 10 :1--this means a CD of 700 MB size with 10 tracks will become an MP3 collection of 10 tracks approximately 70 MB in size (this is a standard 128kbps audio quality CD) If the encoding is less (64 or 32kbps), the size of the resulting MP3 is smaller.
The hands down best ripping software to convert your audio CD to MP3's is called Goldwave. Although Nero and Winamp have functionality on a limited basis for this task, Goldwave is a far superior software package to not only rip, but also edit your creations. Once you have installed Goldwave, you use the OPEN CD button to read your files---then save them to your hard drive (in what CODEC or quality you want---MP3, Apple AIF, OggVorbis, etc.etc
Mar 27, 2009 | Pioneer DVR-107D DVD±RW Burner
Burning a wmv file onto a dvd from my laptops dvdrw
Windows Media Center is the best method for burning WTV files to a DVD.
  1. Choose Start?All Programs?Windows Media Center. ...
  2. Stick a blank DVD (or CD) in your DVD drive. ...
  3. To create a DVD that can be played on your TV, select the Video DVD or DVD Slide Show option and click Next. ...
  4. Type a name for the DVD and click Next.
More items...
How to Burn a DVD in Windows Media Center - dummies
www.dummies.com/computers/...7/how-to-burn-a-dvd-in-windows-media-center/..
or go to this link should help you out..
How to Burn DVD in Windows Media Center dummies
Oct 27, 2017 | Computers & Internet
Will not write dics
What burning software are you trying to use? Also, try uninstalling and reinstalling the hardware from Device Manager
Nov 15, 2006 | Mitsumi (CR-4804TE) CD-RW Burner
HP (178373133) (Refurbished) (178373133) CD-RW Burner Logo
139 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
