Missing channels Digital channels missing 9,7 &2
    Top Expert:
  • Televison & ... Master
  • 35,672 Answers
When you search for active channels, your TV can't detect those particular ones. This could be due to the antenna you are using or its position or location. Tuning can be tricky and favorites seem to come and go
Posted on Apr 26, 2013
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
Shoud this model be able to record digital channels, as I have only been able to record analogue channels to date - I am based in Western Australia - I can view all the digital channels on my TV but to...
Samsung DVD R150 recorder only picks up channels 2 7 9 10 &28, no digital channels, is this all it will record or am I doing something wrong with the installation?
Dec 02, 2010 | Samsung DVD-R130 DVD Recorder
How do I get my Coby 15" hdtv to work with my
slide the switch on the top of the remote over to tv hold select and mute at the same time the green light on the top of the remote will blink green twice then press 9 then 9 then 1 the light on top will blink again then press the channel up button untill tv turns off then press select if you missed the code do the same steps but instead of channel up press channel down till the tv turns on it will only be a 1 or 2 pushes on the channel down if code was missed let me know if this helps
Oct 27, 2010 | Televison & Video
I have my bose v1 equalizer connected to my 3375 harmon kardon the following way.....equalizer(line output..to receiver tape monitor in) and equalizer (line in....to reciever tape rec output ....i am not...
I bet it would work if you listened to something 2-channel and analog. THAT is the limitation of anything that uses a proccessor (like the 901's) and modern AVR's.
Multichannel AVR's automatically disconnect digital inputs when a tape loop is activated.
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the 3375 doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually
You COULD place some RCA Y-splitter cables where the Pre/Main jumers are and send a stereo mixdown instead of true front channel to the Active EQ and thence to a separate amp, but it's not true front channel. But you would have local control of the 901 volume after you calibrate them to match whatever other speakers you use.
When did they stop making AVR's with 7.1 pre-outs? My 9-year old Pioneer has them and I have 901's, 301's and a sub going.
Oct 15, 2010 | Bose 901 VI Main / Stereo Speaker
Channel 97 does not work
Those channels may have been moved to digital channel line-up by cable company. Check with cable co.
Apr 18, 2010 | Televison & Video
Hi - I have a LG 42LP1D, I have tuned the digital stations, but it only starts from Channel 10. So I am missing 1 - 9
Are there Digital stations at 2-9? I'd try a rescan to find all channels it sees. If you are getting TV from over the air antennea, then it might be since the switch over the channels you might have been receiving before are not strong enough now that they are digital. Some locations are experiencing this.
Nov 23, 2009 | LG 42LP1D 42 in. LCD HDTV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Missing channels
Wait for the Weather to change, when the rain returns and this anticyclone moves away.
Mar 12, 2009 | StarTech.com StarView SV211K 2-port KVM...
Car audio
As long as the crossover keeps the frequency going to the tweeters within a safe range (I'd say about 500hz+, read the box or look it up by model number) they should be just fine. That is what the crossover is for.
Apr 01, 2008 | Car Audio & Video
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
