Question about Sewing Machines
I have a consew 210. When moving in reverse it is fine but to move forward the needle gets stopped by something metal below.
  • 323 Answers
SOURCE: The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Posted on Jun 12, 2008
SOURCE: TIming Consew 210
what Brand sewing machine you got and model
Posted on Aug 27, 2008
bilabon
  • 46 Answers
What is the length set at?
Are the feed dogs visible at the needle plate?
What does the design look like in the pattern box?
Have you tried it on the straight stitch to see if is effected also?
Bonnie
Posted on Nov 06, 2008
bibleman01
  • 334 Answers
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
RickE1
  • 202 Answers
SOURCE: I was using a basting stitch and sewing along and
Hi this is a common problem with Berninas 930 - 1630. The problem is that there is a small pin that electromagnetically engages and disengages the needlebar when in basting stitch. If the basting stitch is not used much (or ever) the oil will harden or dirt will get in it and cause the small pin to stick. Therefore the needlebar will not engage. Possibly by softening it up with a blowdryer in the needlebar area (the slot in front) and tapping it etc. it might free up. Otherwise it jneeds to have a tech look at it. Its 50/50 whether it can be freed up from the outside. If a tech has to go to the inside and take it apart and clean it it could be more expensive. I always tell people to excersize their basting stitch. Use it or lose it. I hope yours will free up easilly. Time to have it serviced maybe. Good luck.
Rick
Bernina tech
Posted on Oct 08, 2009
The feed dog is up but has stopped feeding
Are the feed dogs moving at all--like moving toward the back of the machine, dropping down below the needle plate, moving forward, rising, and then moving toward the back of the machine? Make sure the stitch length is set high enough to actually move the fabric--not set at zero or near zero. If the feed dogs stay below the needle plate, then most likely they have been dropped for darning.
If the feed dogs are frozen, not moving, and it is an older mechanical machine, they may be seized due to old oil.
Wheel on right side that controls the needle up and down is very tight...
Or, the feed dog mechanism is broken.
Sep 01, 2017 | Sewing Machines
Consew 328 rb split needle bar not operating
it sound like the machine needs to be checked to see if some part is broken or loose
Mar 29, 2012 | Consew Sewing Machines
The feed dogs will not move and the hook will not pick up the thread. It is a Consew 369RB-1.
Did this sewing used to work just fine? Or is this a new unit and it has not worked since you got it? If the feed dogs are not moving then something must be jammed up in there.. can you see any indication of whats stopping them from moving?
Please give me a bit more detail here about how it got to be this way and I can help you out.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Nov 05, 2010 | Consew Sewing Machines
I recently moved and can't find the belt to my Consew 226. Having problems finding a replacement. Can you help!
Go to www.consew.com and download the parts list for the 224 Consew. It's the same as the 226 for parts. Or, go to www.diamondneedle.com. They have nearly every part you're likely to need. I got bobbin case screws, a hook, some metal reusable bobbins, and some needles, all at very reasonable prices.
Oct 16, 2009 | Consew 226R-1
Bonnie
Sep 21, 2008 | Kenmore 15516 Mechanical Sewing Machine
Consew 226 r sewing machine
do you have the user manual?
Sep 15, 2008 | Consew 206RB
What parts do you oil a Consew 315R Sewing Machine?
Any part that moves and rubs Such as the needle bar , the presser foot bar, the linkage that moves the needle up and down, the bushings at the end of each shaft (Top and Bottom). All the red spots you see on the machine.
sewman7
Jul 09, 2008 | Consew 199R-2A Sewing Machine
sewman7
Jun 09, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
