Question about Toshiba satellite c660
Buy motherboard motherboard shorted
Pc beep code 1 long 9 short beeps = bios rom error
Your Motherboard is broken when the pc beep in that try to buy new one
Dec 03, 2013 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
Cat peed on mb it will not boot now
It's fried, you might as well buy another motherboard or new computer. Liquid on a motherboard shorts it out.
May 23, 2012 | ASUS A7V8X Motherboard
Motherboard short circuit
Not possible, best to buy a new motherboard or a new computer.
Feb 19, 2012 | Dell Studio One 19 (DDDASA1) 18.5 in. PC...
Motherboard displey not comes but processor fan is very fast run & big sound
Hi sagar_naik29 !
Probably a short cut inside your motherboard and / or processor . Not worth reparing .
Consider buying a new one .
Regards
Feb 21, 2011 | IBM (25P3294) Motherboard
I have a HP Pavilion DV9418 17" laptop with AMD Turion 64 X2 Dual-Core TL-58 1.9GHz I am told by Staples it has a short in the motherboard where would I buy a new motherboard, hirst9@sympatico.ca
the best place to buy any laptop motherboard is Ebay. Most computer stores or repair shops they don't carry motherboards due to the vast option of brands/models and remember each laptop has an especific size, number of ports, etc.
Just keep in mind when looking for your motherboard make sure is for the CPU you have.
If you search DV9418 on Ebay you might get one for Intel CPUs and others for AMDs. If you have the motherboard's part number would be the best.
I hope this helps.
May 06, 2010 | HP (D7580-60003) Motherboard
Not booting, 8 short boots, but VGA card
plug in the moniter.... mabbe that helps... or buy a new comp easy fixed
Apr 10, 2010 | Mercury P4VM800M7 Motherboard
Toshiba Satellite L355 s7831 shorted out orange juice spilled on pc I need a service manual part diagram
It is advised that you buy a similar motherboard and copy the systems installation. I know that you are smart
enough to do it. Or you can bring your PC to PC parts
and service stores, buy *********** board there, and let them install the motherboard for you. In this manner, you
can have a service warranty and your PC working again.
Dec 09, 2009 | Computers & Internet
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Short circuit in vcc and ground
Some questions first: Is this the same board mentioned in your other post? If so how did you decide that you have a short on your motherboard?
Jan 30, 2007 | Gigabyte GA-8VD667 Motherboard
Toshiba satellite c660 Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
