Question about 1974 Rolls Royce Silver Shadow Antenna, 74 Rolls Royce
Squealing Steering When I turn the steering to a full lock at low speeds like when parking, there is a loud squealing noise coming from under the hood. Could someone please help?
  • 2,259 Answers
Certainly. The squealing is the power steering belt, and it is slipping. If you tighten it, and it still squeals, it is worn out and must be replaced. The belt should be tight enough that pushing on it with your finger will barely cause it to deflect.
Please take a really good light and look at the inside of the belt, and look for cracks. If there are cracks, you will need to replace the belt. However, a belt can also be no good if it has no cracks, and that is if it is too old. Most belts have a life of around 5 years, some go as far as 10, depending on the use of the car and what kind of weather you have.
Be blessed.
Posted on May 11, 2013
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Loud noise when power steering is on full lock Kia Sedona 2004
There may be 2 possible causes for this problem. THe first may be cv koints failing or excessive turn angle of the wheel which would be binding up the cv joint. This can be checked by a wheel aligner testing the maximum turn allowed at the wheels.. The second is that power steering pumps should never be operated at tight full turn. To umnderstand this consider this. Power steering pumps are only under load when you move the steering wheel ans if you turn a bit the pump moves the wheels and then the pressure is let off until you move the wheel again. You have to move the wheel to shut off a valve in the box that allows the pump to build up pressure. When you hold the wheel hard against the stops at full turn you are making the pump work at maximum pressure and if you continue to do this you can expect premature pump failure. Jusat turn until you hit the stops then ease off a fraction. The noise I expect is the pressure relief valve in the pump is releasing rapidly and it probably sounds like a hammer hitting something metalic. Try the alignment and try not holding the turn hard at hard full turn. Haveing the pump pressure checked might also point to a fault
Feb 07, 2013 | Kia Sedona Cars & Trucks
My lexus sc 300 makes a squealing sound when I start it, and when I turn the wheels sharply to the right and left (while it is parked and running. My power steering pump supposedly has to be replaced,...
Hi Genebaran, I doubt very much if the steering pump needs replacement, but the drive serpentine belt does. The squealing happens because the belt is slipping on the pump pulley when the pump is under load when the steering is turned to full lock. By the way, don't keep the steering wheel at full lock for longer than a few seconds at a time, as it will place the pump under too much load! Tell your mechanic to fit a new belt. Advise the mechanic to make a sketch of the routing of the belt before he removes the old one. Regards Johngee10
Jul 22, 2011 | 1992 Lexus Sc 300
When turning wheel a squealing noise comes from the steering coloum.........seems like it might be worse going into a corner hard........may sound like something turning in the coloum itself...............
The squealing noise when turning the steering wheel happens in most cases when the power steering fluind is low. Check to see if there is power steering fluid in the reevoir. If not add fluid to the proper level and the squealing should stop. Good luck
Feb 11, 2011 | 1993 Honda Accord
2003 Saturn VUE Steering Column Noise and Resistance
i am a saturn tech and ive never heard of this concern,the columns do go bad but they just set a ses light and cut out power,the column could be bad,it could also be the intermediate shaft u joint binding,,,i rec take to dealer, could be serious
Oct 03, 2009 | 2003 Saturn VUE
When I go to turn the wheel in my 2000 ford ranger I hear loud squealing noises. I checked the power steering fluid and its full. What can it be?The squealing starts as soon as I turn the wheel to the left...
The power steering pump is normally connected or driven by the engine with a V-belt. A loose belt can cause squealing as soon as the power steering come under load (e.g. steering left or right while stopped).
Check the tension on the V-belt directly connected to the power steering pump. This may need replacement.
Hoep this helps.
Jul 01, 2009 | Ford Ranger Cars & Trucks
Loud squealing noises when I turn the wheel of my 2000 ford range
It sounds like the power steering belt is too loose, tighten it up a bit but not too much just enough to make slipping belt stop.
Jul 01, 2009 | 2000 Ford Ranger SuperCab
Engine squealing
Only two choices a belt pulley bearing or the ps pump.
Sep 22, 2008 | 1999 Mercury Cougar
1974 Rolls Royce Silver Shadow Antenna, 74 Rolls Royce Logo
88 people viewed this question
Top Replacement Vehicle Parts & Accessories Experts
David Ellis Rhea
Christian Krentz
Christian Krentz
Mike Kolbay
Level 1 Expert
Are you a Replacement Vehicle Part and Accessory Expert? Answer questions, earn points and help others
