I have a ivew 760tpc and its not charging.. i have yo leave Tue charger on it .. also it has the android guy in the.middle of the screen . It won't go to.home screen at all , and when i hit press the power button it goes blank and i hear a pop . How do i fix it . ???? Or do i have to.send it in??? .
  • 7,627 Answers
You could post to the Tablet category and get a solution from a Tablet expert. If it's under warranty return it. Has the Cord/charger been damaged due to pulling on the cord while plugged in causing a short or loose connection? If the "pop" is followed by a electrical burning smell, return or have a Qualified Tech take a look at it, it COULD be a fire issue if left unattended and plugged in.
Posted on Apr 26, 2013
5 Suggested Answers
  • 8 Answers
SOURCE: Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Posted on Jan 19, 2009
parrotheadpc
  • 2600 Answers
SOURCE: screen goes blank every 30 second, have to hit the
go to control panel > power options. Turn off hibernate and sleep mode, change all settings to never sleep and change the setting for "when closing the lid" to "do nothing" sleep mode, hibernation can destroy the registry on these laptops, you are better off turning that garbage off and just letting it run.
Posted on Nov 16, 2009
  • 214 Answers
SOURCE: when i press the power
I believe blinking lights on the Caps and NumLock means that there is a problem about the Hardware, I've been a Tech Support for HP and those blinking lights are problems for Video Card, CPU, Memory.
It would be better if you call the manufacturer try if they can service your machine.
Hope it helps. =)
Posted on Apr 19, 2011
  • 11800 Answers
SOURCE: My MSI MS-1683 Laptop With
That blinking underscore is the way in which the laptop's BIOS is telling you that it didn't find any Windows to boot to - it was completely corrupted.
The only thing left to do is to reinstall it.
Posted on May 29, 2011
Kocaso comes on but only shows the word android
It is not loading the operating system, only the Linux starter program. try power resetting it.
you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Jun 04, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Can not move past Android screen HELP
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Feb 05, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
SCREEN LOCKED UP AT android
Jan 30, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
I cannot access internet it says I have drivers missing I have a KOCASO M9100 android 4.2
The drivers are built into the firmware, so this is unusual.
Jan 25, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Kocaso M736 is stuck on the Android screen
Jan 23, 2014 | Kocaso M730w 12ghz 4gb 7 Capacitive...
My tablet wont work at all
all I cant suggest if its still under warranty take it back to place of purchase,my flatmates boy had same problem the guy at the shop where it was brought from fix it in about 2minutes and no charge .
Jan 17, 2014 | Nextbook Premium 7 Capacitive Touch...
My iview 754tpc tablet won't leave the adriod screen
you must download a file on this side: http://www.iviewus.com/download/754TPC.rar .Good Luck...!!!
Dec 08, 2012 | Iview 760tpc 7-inch Tablet
When switced on android sits in middle of screen
The green android guy is in the middle and it doesn't change after even the longest of times? Well then this might be a factory defect, because this means the Android Stock OS isn't installed properly.
The only way to fix it would be to void the warranty, and that's the last thing we want.
May 10, 2011 | Coco Android 2.1 Tablet (837121001186)
Fischer and paykel scooter model sc231ala not charging
hi, if you got a meter , check the voltage o nthe charger socket , it should be about 24v,
that is the left and right pin, not the middle pin that is slighly lower,
if the voltages are going up and down goto the batteries first and chec k the connections on the terminal, tight ?, check them back the the charging socket, normally the charging socket is wires indirectly to the batteries.
Regards
GeWiz.
Jan 08, 2010 | Health & Beauty
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
