Question about Ovens
Manuals need haier microwave oven
    New Friend:
  • 13 Answers
Consult a technecian
Posted on Apr 26, 2013
Haier RTC1700ss digital display doesn't work. Beeps when plugging in but no functions
Hello
Here are a few things you shoul look at and try to correct to make your oven work properly
Make sure the electric oven is plugged in properly.
Check that door closes completely and its latch is aligned.
Check that interlock switch in door works properly (required for activating oven).
There might be a blown fuse,replace blown fuse if it's accessible, or contact a service technician.
Inspect plastic coupling beneath tray.
Check ring and roller assembly for misalignment or debris.
Make sure that tray is sitting properly on turning mechanism.
If carousel motor is broken, contact a service technician
Make sure there's no aluminum foil or metal trim on dishware.
Food residue or burned spots can cause electrical arcing. Clean chamber thoroughly. Replace wave-guide cover if burned or carbonized.
Sand away burn spots, and smooth rough metal edges.
Touch up spots with microwave interior paint if necessary.
If chamber has burn holes, contact a service technician.
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Jun 20, 2011 | Haier RTC1700SS Electric Single Oven
I just got an old microwave and don't now how to use it. Please is there a way to find a user manual? National Dimension3 Microwave/Convection oven
Try the Panasonic website below. National became Panasonic a number of years ago. I just went there and did a search for demension 3 under microwaves and it definitely has a few results for instruction manuals. You will need your model number (most likely on the back of the oven)
http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation
Good luck :)
May 04, 2011 | Ovens
I have Haier Hr-18G microwave oven I don't know how to operate it
Jan 25, 2011 | Ovens
Can we use non stick pan in a microwave?
Non-stick pan I think may be surely made of metal. Its always
advised not to use metal pans, dishes, spoons etc inside the
microwave oven. Metals are mainly avoided due to the effect
of the microwaves on the metals.
These ovens uses the microwave radiations generated from a
magnetron. The microwave radiations are reflected off by the
metal surfaces. So if you use metal pans inside the oven, they
act as a microwave antenna that reflects back the radiations to
the magnetron and can cause damage to your oven. Another problem
with the metals inside the oven are due to arcing effect.
The atoms in the metal are ionized and the air gap near them lead
to a lightning like discharge of energy causing sparks. This can
easily cause a fire inside the oven since the food materials may be
easily ignitable under that temperature.
Alternatively you could check the manuals of your oven to confirm
the type of dishes that can be used to cook inside. If no
user manuals are available check manufacturer website.
Considering the safety, its a "No" to use metal pans inside the oven.
Dec 26, 2010 | Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Microwave Oven Manual
Why won't you help for free
Aug 08, 2008 | Ovens
Whirlpool RMC305PDQ1 Oven-Microwave Combo Unit
is this model mounted over the oven as one piece unit?or does it hang above the stove?
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
Jenn-air microwave light bulb
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
