Question about Indesit Washing Machines
No water feed to indesit washer
I have a Indesit IWE91840 washer, after getting a F05 error code I have cleaned out the filter and removed coins from the black hose which runs from the drum to the filter. All is now clear and working and the washer will run through a cycle without error codes etc but there is no water entering the drum. The water feed pipe is fine and there is a good level of water pressure? any ideas? is there a way of resetting the machine's computer after a fault?
5 Suggested Answers
SOURCE: WD12 Indesit washer/dryer
my indesit wd12 is not spinning
Posted on Jan 28, 2008
SOURCE: my Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Posted on Apr 29, 2009
barkencoa
  • 3463 Answers
SOURCE: fault code F05 on an indesit washing machine WIXE
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove large black fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hop[e this helps you.
Posted on Dec 28, 2009
  • 884 Answers
SOURCE: indesit washer not draining
Check filter not blocked and pump turning freely
Posted on May 10, 2012
Indesit dishwasher 705. Error codes 1 and 3 (left to right) flashing. Not blocked filter as it drains water away.
Find the error code on the web so you know what the washer is complaining about (Google it). Because the washer drains water does not mean the filter is not clogged. Remove the filter and clean it to be sure.
The error code will point you to the requisite corrective action. An error does not necessarily imply failure, but it usually means just that.
Until you know what the washer thinks is wrong, you have little chance of correcting it.
Good Luck,
Pete
Jul 19, 2015 | Indesit Dishwashers
Indesit pwe 8148 w with error code FO5 Is the problem usually either a blockage or the pressure switch? I am going to try to fix it myself but how do i get to the pressure switch to see if it is stuck on...
Hi.
F05 means that the pressure switch shows full all the time:
F05 - Pressure switch jammed on full
The fault is usually fixed repairing or replacing the pressure switch. Before replacing the switch check for draining issues that can trigger F05 and clean the hose connected to the PS. The PS is located inside the appliance in the control panel or at the right side of the cabinet. The part is reached removing the screws holding the top and lifting the top. Power must be disconnected before starting.
Here how the switch looks like:
Sep 14, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Locate and remove the large black fastened to bottom of the drum.
Hope this helps you.
Jan 03, 2011 | Washing Machines
F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Fault code f-05
Error code F05 denotes the pressure switch is jammed on full.
Remove the large black hose on bottom of drum.
Refit and test.
Thankyou.
Jan 31, 2010 | Indesit W 123 Front Load Washer
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Dec 28, 2009 | Washing Machines
My indesit W1E167 1600 washing machine is flashing F-05, is there anyway I can unlock the door? It seems to go through the wash cycle but then perhaps gets stuck on the spin?
Error code F05 indicates pressure switch jammed on full.
Remove hose onto pump, check for obstruction here and in the pump.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Select Brands Washing Machines
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Jan 03, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
