Question about Sharp Audio Players & Recorders
Sharp MT270H player plays but wont record or edit and says err-MD41 if I try to edit
simplemitch
  • 752 Answers
SOURCE: wont play recorded cd's
thats a "table of contents" error. Try using a different program to make your cds.
Posted on Sep 15, 2007
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
SOURCE: my built in cd player is stuck on (err) and wont play cds
Your radio is in anti theft lock out.. You can google the help page to do it yourself,or a dealer can do it for you.. some at litle charge,, some full price,, takes 5 minutes,,,, If a local garage has a Tech 2 scanner they can do it as well. BUT the instructions are online,, Ill hunt for them,,,,,,,
Posted on Apr 02, 2009
OnlyOneN
  • 86 Answers
SOURCE: record player not working
Hi Allan,
Unfortunately it sounds like the belt either broke or is slipping. If you're up to it, you can order a replacement belt from a few different places online. As I haven't messed with a turntable in years, I can't make any personal recommendations. A quick google search returned this company, though... http://www.turntableneedles.com/
You'll need the current belt measurements before you order a replacement. And, disassembling the unit will confirm if the belt is broken or just slipping. (Or, better yet, slipped off the pulleys!)
Keep in mind that replacing the belt can be a daunting task.
Posted on Apr 20, 2009
  • 700 Answers
SOURCE: Can record and play on player, wont play on computer
You must have a dvd rom. And install k-lite codec pack. this should do it.
Hope this help
Posted on Apr 28, 2009
My sharp mdsr60 minidisc displays a er-md41 after recording! Is there any way to fix that
Since most Japanese companies use same/similar set ups, er-md41 is likely to be the same code on several machines, through research I've found that it likely to be dust on the lens.
unless you are familiar with cleaning MD's, I do not suggest that you clean it yourself.
Jan 05, 2017 | Sharp Audio Players & Recorders
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
Cd stack in cd player,screen shows err
My CD Player did the same. It showed an "ERR" message when trying to detect the beginning of a CD. I thought that the CD was dirty and wiped it down. Then I discovered that the player would detect the CD when the car was idle, but not when the car was in motion. Maybe the laser is THAT sensitive. Hope this works for you.
Jun 29, 2009 | 2002 Nissan Sentra
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
Sharp MD MT-80H(S) not playing sony minidisc 80
I had a similar problem after not using player for several months - "Can't read" message displayed every time I put a recorded minidisc in the player. Seem to have solved it (maybe only temporarily) by opening the player, inserting little finger in at the righthand front and sliding movable mechanism from side to side. It looks to slide on a bar which had maybe picked up dirt or damp. Also tried blowing a warm hairdryer into the slot for a minute or two (take disc out first!) to remove any damp. Working OK at the moment.
Jan 19, 2009 | Sharp MD-MT80H Personal MiniDisc Player
Recorded dvds wont play in other dvd players
Sep 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recorded DVD wont play on any other DVD Player
I lost my manual. Can you describe how to finalize it? I can't finad any buttons to press that say finalize on them.
Jun 01, 2008 | Funai TruTech DVDVCR Dual Recorder
Recorded dvd
You are probably having an issue with the discs rather then what you are trying to play them on.
The discs need to be finalized before they can be used on another player.
  1. Put the disc in the drive (the ones you have already recorded)
  2. Press SETUP on the remote
  3. Select - Disc Edit Press OK
  4. Select - Finalize Press OK
Wait until it is finished then try to play them on another player.
Apr 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
No edit
have you finalized the disc before trying to play it in another player?
Feb 20, 2008 | Aspire Digital AD-8091 DVD Recorder
Wont play recorded cd's
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
