Question about Miele Washing Machines
Miele w 489i WPS
Severe vibration/knocking a full spin speed with electrical? smell when door opens
  • 79 Answers
SOURCE: strong electrical smell with smoke coming out
Check the lower motor control board. See www.neptunehelp.com for disassembly pictures. It is possible you will need to replace the motor control board and motor if you have the original one as Maytag has redesigned these two components due to reliability issues. The new motor conversion kit is part # 12002039.
If there are any burnt components on this board then it will have to be replaced. There is also a 10 amp fusesoldered to the board. if this fuse blows the tub will not move anymore and the motor control board / motor will have to be replaced.
Have you noticed your Neptune's spin cycle getting loud? If so, the seal kit and bearings need to be replaced. See www.neptunebearing.com for more info on the special bearing tool kit you can rent that includes use of a DVD that shows you how to disassemble Neptune, replace bearings and install the seal kit.
Posted on Feb 18, 2009
SOURCE: severe vibration during spin cycle
reduce the amount of cloth and make sure the cloth don't fix in one corner
Posted on Mar 23, 2009
  • 128 Answers
SOURCE: Miele W1926 washer shakes more then usual when spin.
I'd start simply.
They do move over time and if the floor is not even the machine will be out of balance.
If you have not done so check the machine is still level and all feet are solidly on ground.
Try to shake the machine by hand and see if is solid on the ground. There are leveling legs under the unit you can adjust.
Hope this helped. Please rate answer if it does.
Posted on Mar 11, 2010
2coolrick
  • 560 Answers
SOURCE: I have a Miele W404SB
1. Make sure the washer is level first, with a small torpedo level at the top center edge of the washer ,check at the front and one side. If its not, adjust the 2 front level foot adjusters (at the front of the unit where they touch the floor) to level the washer.
2. If level is ok, check the door seal and replace if cracked or torn or old and hardened.
3. If ok, look at the latch on the door and the washer. Some have an adjustment for how far the door closes to latch. There will be 2 screws or small bolts you will loosen to slide the lever or the latch plate to adjust so the door closes tighter.
4. If ok, then the water level sensor will have to be replaced by a qualified tech.
Posted on Sep 04, 2010
Geekman
  • 32281 Answers
SOURCE: high speed spin vibration and knocking
This indicated the load in the washing machine is unbalanced. Open the machine and move the clothes in the drum so it is evenly distributed in the drum.
Posted on Feb 05, 2012
Dishwasher got stick in drying cycle
It sound as if the machine is not getting any water - either the WPS or level switch. If you can feel the big Module connected to the water intake under the sink - does it vibrate slightly? if so then the WPS needs to be replaced.
It could also possibly be a dirty filter at the inlet not letting enough water into the machine in the time window programed - check the filter first - but my money is on the WPS
Aug 19, 2014 | Miele Dishwashers
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
Jan 08, 2014 | Miele W1926A Front Load Washer
2006 Toyota Tacoma Prerunner, 2WD, 4.0L V6, 5-speed Automatic has a severe vibration from the speed of 20 mph to 50 mph, then the vibration will slightly deminish.
Is it the engine vibrating or the car? If its the car itself it sounds like u need to have the tires checked & balanced.
Mar 16, 2017 | 2006 Toyota Tacoma PreRunner
Loud thumping noise in spin and smell of rubber with smoke when door opened
there are diffrent kinds of front load units some have rotor and stator issues you sound like yours has motor with belt possible bad belt or motor.
or its shaft and bushing is going.
Nov 02, 2012 | Miele Novotronic Premier 500 Front Load...
Drum is making a loud banging noise during spin, it is brand new
Some banging or knocking during the ramp up to spin speed in this washer is normal. It is difficult to determine whether your washer has a problem or not based on your description. This banging lasts for varying amounts of time until the load is balanced and the washer ramps up to the full spin speed. If the load can not be balanced on the first attempt, the washer will ramp down and then tumble and attempt again to ramp up to speed. This may be the same thing that you are hearing when your washer ramps up to spin speed. Since the washer does spin at the full speed, there is not likely a problem with the washer. The components are designed to withstand repeated vibration and reasonable banging or knocking. The washer will vibrate to some extent at high speed. If you feel that the vibration is excessive, I recommend that you check the stability of the leveling feet. Press down on the diagonally opposing corners of the washer to check for play. If the washer rocks at all when conducting this test, I recommend that you adjust the leveling feet to eliminate this play even is the washer is not perfectly level after making this adjustment. This may help reduce the banging and vibration. Other than that if it is brand new call the people who you purchased it from so you don't void any warranties by taking it apart.
Sep 08, 2011 | Washing Machines
What does it mean when F 14 is displayed in the window?
F14 - "level/pressure switch failure." The level switch monitors the dishwasher's water pressure, as it circulates, which is especially critical, during the heating cycle (main wash). Level switch failure can commonly happen from poor circulation, or from the defective level switch, itself. The most common reason for poor circulation is low water fill level. In other words, during the water intake cycle, insufficient water came into the dishwasher. Observe if enough water did come into the dishwasher, Check the water level, by using the filter's handle (located on the floor, of the inside of the dishwasher) as a reference point. At the end of the water fill stage, the water level should be just underneath the filter's handle. If the water level is more than half an inch, below the filter's handle... then that could be a problem. The sympton would be a noisy, sluggish, whooshing sound of water, during circulation - It wouldn't be the same old quiet Miele dishwasher you knew.
If you have the low water fill problem, then look at the dishwasher's water intake hose. Miele call this their Waterproof System hose (WPS). It's a water hose with an integrated electric valve. First, shut your water valve that connects to this WPS; disconnect the WPS from your valve; look inside the end of the WPS. With a needle nose plier, remove the rubber seal, filter and the water restrictor; clean them of any possible debris; put all the parts back into the WPS, securely; reconnect the hose; open your water valve; and test the dishwasher. If the problem persists, then the WPS will need to be replaced (WPS~$170).
Other causes for F14, can be weak circulation from foreign item(s) (plastic wrapping, broken glass, etc,...) lodged inside circulation pump impeller, or no circulation, at all (circulation pump stuck). Of couse, the defective level switch, itself, can cause the F14, too. The least common causes for the F14 can be broken wires to and from, level switch and electronic unit, and a defective electronic unit.
Oct 18, 2010 | Miele Premier-Plus Built-in Dishwasher
My dryer flew off of a dolly when loading it on a trailer to move it. It smells like rubber is burning when I turn the dryer on. It was working fine until we moved the dryer. Could it be the belt is loose?
If the dryer fell some distance, the drum is probably out of alignment.
If the drum is not spinning at all, something has jammed the drum and the belt is being overheated by the motor pulley.
If the drum is spinning and there is a rubber smell, the drum has been knocked off of its rollers and/or glides.
In either case, the dryer needs to be opened. Click the link below:
http://www.applianceaid.com/may-apart.html
There are two basic types of Maytag dryers, older models and the newer ones with the door that wraps over the top ('L' shaped door).
Apr 07, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Miele W1926 washer makes a banging sound when it spins
if i were you fist of all open door then you will see the silver drum on the inside lift the silver drum upwards from the top of it and if you feel a knocking sound then the bearings have worn out expencive to replace them,as sometimes you have to have a complete new drum.rgrds,paul
Jul 07, 2009 | Washing Machines
Bearing Follow Up
it does seem a bit odd that vibration and out of balance are ascribed to bearings. normally when bearings go, the symptom is just noisy bearings.
vibration can be from several sources
if the spin cycle does not ramp up to speed ie does not work up to spin speed but goes straight into spin, then there will be vibration
if shock absorbers are worn, there will be vibration.
if the washer is not solid onto the floor there will be vibration.
if the floor is a suspended floor, there can be quite severe vibration. some modern floors (in the UK at any rate) are made from a form of chipboard called weyrock. with joist spacing greater than in the past and with weyrock as the floor cladding, quite severe vibration can result
Sep 09, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
