Question about Miele Softronic W 5922 Washer
Miele w 489
Severe vibration/knocking at full spin plus electrical burning smell
2 Suggested Answers
  • 3356 Answers
SOURCE: Our Miele washing machine made a very loud noise whilst spinning. Burning smell.Smoke coming from back. An engineer was called out last month. Drawer issue. But think he serviced it at same time. Ty
There are several things that can go wrong and cause noise and/or smoke.
Knowing what the noise sounded like or how the smoke smelled would give a clue but the only way to discover the true cause would be to remove the top or back panel and take a look.
There is not much to service on most washing machines - certainly not in the short time an engineer usually takes when he visits. A service amounts to a visual safety inspection more than actually carrying out any maintenance. These days it is likely to begin by plugging in the laptop to discover what sort of usage the machine has had since the last time and how many times it has been overloaded and so forth and if the brain has logged any faults.
The engineer should then check the suspension for security and condition, the condition of the visible hoses and seals, the belt, the security and adjustment of the motor and probably the amount of wear left on the motor brushes and the security of the wiring and so forth. He would finish by inspecting the filter(s)/traps and cleaning them and running briefly through the programmes and listening to the bearings.
If the service didn't reveal the need for extra work it would take a competent engineer about an hour to do including drinking his coffee.
If the service was competently carried out the machine should have been good for around six months of hard work without forseeable problems.
Having anything serviced properly vastly reduces the chances of a breakdown but doesn't eliminate the chances entirely. I guess what you are asking is could the engineer have possibly made a contribution to the breakdown?
Good white appliance engineers aren't as common as mediocre and bad engineers but even good ones are capable of not getting things right sometimes, especially as companies tend not to be overstaffed and the chances are his boss wanted him somewhere else a couple of hours before he even reached you...
Sorry but I can't comment further without more information.
Posted on May 05, 2016
Why is my miele t220 novotronic have a burning smell when working
If lint material has collected around the heating element this will happen. Locate the element and clean out all debris, lint, etc.
Sep 01, 2015 | Miele Novotronic T220 Electric Dryer
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
Jan 08, 2014 | Miele W1926A Front Load Washer
MY DRYER VIBRATES VERY BADLY, THE CLOTHES STILL SPIN BUT THE WHOLE UNIT MOVES ALOT AND AFTER A FEW MINUTS IT STARTS TO SMELL LIKE SOMETHING IS BURNING.
This sounds like the rubbing strips at the front of the dryer are badly worn and/or the rear bearing is worn. From your description - the drum is sticking - causing the motor to slip on the belt - causing the burning smell.
Replace worn parts including the drive belt.
Aug 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My dryer is making noise, vibrating and smells like it is burning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fg
Jul 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My miele s571 hoover is humming from a normal sound to a real low hum sound and their is a smell of burning it even through my smoke alarms off what would be wrong or is it worth fixing
It could just be a slipping belt, hair and lint get under the belt and make it stretch the it slips and the spinning drive post heats it up until it starts burning.
Jun 14, 2010 | Miele S318 Bagged Canister Vacuum
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer smells like it is burning
The belts have stretched and slipping. Replace or run smaller loads until you do repalce them.
Apr 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Miele Cat & Dog Vacuum
doubt it. could be dangerous to use. (had one burn up due to this)
Apr 23, 2007 | Miele Cat & Dog 326i Bagged Canister...
Miele Softronic W 5922 Washer Logo
48 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
