Question about Mad Dog Multimedia (MD16XDVD9) DVD±RW Dual Layer Burner
My MD16XDVD9 doesnt work. Its power is on with the small greeen light flickering and the bigger green light steadily on. but the the DVD tray doesnot open automatically. Even if it is force-opened and a disc inserted, it doesnt play and the computer says "please insert disc". It looks like as if the instrument is in Standby mode or so how can i make it working?
  • NAPA10 Jun 08, 2008
    My Mad Dog MD16xdvd9 only works with a cd. It won't reconize a DVD.
    Novelist:
    Scholar:
  • 158 Answers
Have you got it set on an IDE cable on it's own and if so have the jumper at the back set to master the other thing to do is power of pc and remove ide cable from all devices and leave power cable to burner then torn on pc if you have removed power and ide cable from hard drive then when pc boots in press button on cd,dvd drive to open tray then place cd lense disk or any cd in drive tray press close button and let device kick in if it picks up disk then try with a dvd disk with power on pc if all goes well try with a ifferent Ide cable to motherboard and reconnect harddrive and power up if all goes well the pc should recagonise it if not then get it replaced
Posted on Aug 13, 2007
SOURCE:
Dvd tray pops out by itself
Hi. Sounds like you have a Virus. Do a Full Virus Scan not just the Quick one. It should help.
Nov 25, 2010 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Cd brokes in cd rom
IS IT ON?...DOES CDROM HAVE POWER GETTING TO IT FROM PC? Next to open/close switch there is a small pin-hole. Push a paperclip into this hole and gently pull out tray...try gently pushing tray back in and watch for a blinking green light;if none either the cdrom is not getting power, or it has quit working
Mar 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
The Disk Tray will not open (TDK DED 440 DVD driver)
The lubrication inside your device may be insufficient or some mechanical problem has occurred inside preventing the device to open. Now, look at a very "small hole" near the Tray's front cover. If you see it, get a very small pin or even a needle to fit to that small hole. Now, press the "open" button in your device and then push that pin or needle in the hole at the same time to help the device to open.
Dec 29, 2009 | TDK (ded+440n) DVD±RW Burner
A game is stuck in the tray. The green light is
There is a way to manually remove it. First you will want to unplug the power for a few minutes to let your Xbox reset. Re-attach the power cord and see if you can now eject your DVD. If that did not work turn the power off and unplug it. Remove the faceplate on you Xbox console. You will need a thick paper clip or something similar. Straighten one end of it out. With the faceplate removed you will see 2 small holes right underneath the DVD player and one hole to the right.
Since Microsoft decided to use 3 different DVD drives the procedure will vary. If you have a Samsung or Toshiba drive use the small hole on the right. Should be right underneath the X on the DVD drive faceplate. Push your straightened paper clip in the hole until you feel it hit the gear. The gear needs to be spun from left to right. Poke around until you find it then push in gently until you feel it move. You will see the tray start to move out.
For Hitatchi DVD drives go for the first hole on the left. Beng DVD drives will use the middle hole. This requires the most pressure to get the gear to turn. You will see the tray start to move take your time and do not push too hard in case you are missing the correct spot. Once the tray starts to eject you can pull on it slightly to help it open. You should now be able to remove your Game.
Nov 17, 2009 | Microsoft Xbox 360 Console
Emachine t5026 does not appear to have any power, when you unplug the power cable from unit the ehaust fans breifly turn on, and light on mother board flickers, other than that sign of power Tried putting...
Unplug every thing such as the CD/DVD trays, Hard Drive, take out any dial-up modems, network cards, video cards, etc. unplug even the mouse and keyboard. Try powering on agan. If the computer seems to work, then power back off and plug in one device then power on computer. Keep doing that until you find the bad device preventing the computer from turning on.
If that doesnt work then carefully remove the RAM completely then carefully replace the RAM. Now with on the Dynex power supply plugged in to the motherboard, try again. If still nothing, remove the RAM and try again. If it still does the same thing, then the motherboard is dead and needs replaced. If instead you get a series of beeps then the problem MAY be bad RAM. Try different RAM. If that doesnt help. The only thing left is taking out the CMOS battery, It is the coin shaped battery on the motherboard. Take it out and wait 20 seconds then put it back. I doubt it is the CMOS battery, but at this point it is worth a shot.
Nov 13, 2009 | E-Machines T5026 PC Desktop
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
CD-R Tray Doesn't Work
you can do is reseat the power connector at the back of the drive if that doesnt work ... change the power connector u may have an extra in the tower and than try ... if that doesnt work u have a faulty drive
Feb 07, 2009 | HP Pavilion dv2000t Notebook
My disk tray
Open thje device manager try uninstall and install again.
Jan 03, 2008 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Cd not recognized
Often the Laser for the CD section gets burnt out... I have seen this often there is no fix... Ya gonna haveta get a replacement sorry.
Apr 19, 2007 | Lite On (SOHW1633S) DVD±RW Dual Layer...
Mad Dog Multimedia (MD16XDVD9) DVD±RW Dual Layer Burner Logo
100 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
