Question about Honeywell Computers & Internet
Cm927 Display said low battery, changed batteries, but only half the LCD display is working, is the thermostat defunct , only 3 yrs old
  • Honeywell Master
  • 7,627 Answers
I think you have the wrong category.
Posted on Apr 26, 2013
listeur
  • 88 Answers
SOURCE: dell lcd display
if it is just half of the screen and the rest is black- you need a new screen. If it is half the screen all squished together (you can see the whole desktop) you need to reload the video driver
Posted on Nov 24, 2007
acmilancrazy
  • 38 Answers
SOURCE: vertical red line in display
I had a similar problem with a flat screen lcd for my desktop comp, and it turned out that I needed a new screen if i wanted to get rid of it, but it doesnt really cause much of a problem, so i didnt bother replacing it. If your laptop is still under warranty, (i dont know how long your warranty lasts) I'd look into getting it replaced if it really bothers you. But yes, its definitly the screen.
Posted on Aug 08, 2008
  • 3 Answers
SOURCE: DV4000 lcd goes dim
Have you checked your power options in the control panel to see what they are set at? Has this always been a prob, or is it something that has just started?
Posted on Oct 26, 2008
  • 111 Answers
SOURCE: partial lcd display on laptop
Hi
Sometimes the resolution changes to an unusual setting when an external monitor is attached. make the LCD screen your main monitor and change the resolution to 1024x768 or 600x800 whichever is best.
Happy to help
CBZ
Posted on Apr 26, 2009
  • 5 Answers
SOURCE: Dell C640 LCD dims when on battery power
You can also presss "fn" and the "up" arrow. This will increase your screens brightness.
Posted on Jun 19, 2009
My computer on my Schwinn Airdyne's numbers are only half showing. Is it low ink
the displays use LCD in the display not ink it sounds like the battery(s) are low see about replacing them and the display should return to normal if the batteries are new the display might be damaged due to age, heat, or physical contact with the display i.e. pressing the display, hitting it, something fell on it
Jun 04, 2014 | Schwinn Original Airdyne
Canon 600D LCD screen display problems
cables on the LCD screen needs replacement go to the nearest service center
Feb 09, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Honeywell CM927 display problems
here is no repairing these, if it is not under warranty you must live with it or replace it.
www.honeywell.com
Dec 14, 2013 | Heating & Cooling
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
Jan 10, 2011 | White Rodgers Water Heaters
No display on Robertshaw 9600; unit seems dead/furnace works
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Repace the tstat. Bad display. Make sure the batteries you put in were good First. Russ
Jul 25, 2009 | Heating & Cooling
Conon powershot a470 i cant find in the manual where the battery life is displayed? is it on the screen? do u have 2 change setting 2 find it? or does this model not display it on the screen?
Your a470 has a "low battery" flashing icon that will appear in the upper right hand corner of your lcd display when the battery is getting low. It doesn't appear to have a constant battery display. The manual recommends when you see the flashing icon... change the battery as soon as possible.
May 15, 2009 | Canon PowerShot A470 Digital Camera
I press the shutter button a red light flashes in the viewfinder
Your focus or lighting is too low for the picture. Add more light, and hold the button down half way to self adjust to see if it goes away. Change the battery to a lithium battery, which helps the digital cameras work their best.
Let me know if this helps.
Jan 24, 2009 | Toshiba PDR-M700 Digital Camera
Computers & Internet Logo
222 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
ray gallant
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
