Question about Toshiba Computers & Internet
Toshiba A505 always shut down if not using charger
  • 7,482 Answers
Hi beebajoe
Replace your battery, it is faulty
Posted on Apr 26, 2013
My Toshiba L200 when i plug adabtor it always shut down. if i use with battery is use normal but when plug adabtor it shut down,what can i do?
First double check your charger is 19V (at 3.42A minimum) on the body label. It could also be providing a faulty voltage so you need to check its output with a cheap voltmeter (should be 19 to say 22 volts off load), OR borrow a 19 v charger from someone which has same connector to see if it works on your laptop. Good Luck.
Dec 23, 2014 | Toshiba Satellite A305 A355D L200 L305...
Can I use a Toshiba recovery disk for A210 series if I have an A505 series? They are both Windows Vista
That is about the only thing thew same about them other than the name Toshiba. The A505 is an Intel Processor, the A210 has an AMD processor. They have completely different video graphics chipsets, audio, and LAN configurations, Assuming that the A210 disc will load in the A505, you would not get proper video, audio or LAN drivers. Recovery disks are made for the machine they are bundled with. You can try, but don't be surprised if your result is less than optimal.
Jan 06, 2012 | Toshiba Satellite A505-S6034 Laptop...
A505 S6970 Toshiba laptop HDD#1/SDD#1 password
Maybe you mean log on password. If you never enter a password to log on, but suddenly when turning on the computer, you are prompted to enter a password to log on, but always failed. You try to log in using an administrator user but failed. Chances are, the operating system is infected with viruses.
So, the operating system has controlled the virus.
solution:
Install the new operating system (not repair the operating system)
Nov 27, 2011 | Toshiba Satellite A505-S6970 Notebook
Satellite A505 laptop running windows 7 64 bit when using shutdown options and selecting sleep mode system does not go to sleep it freezes and must be manually shut down which generates a windows was...
Sleep and hibernate options are part of Bios. what i mean by that is if these is an issue with Bios these features wont work. Sometimes there has been known issues with cordless mice and other devices plugged in via usb port. Also outdated video and other drivers will do same. i would recommend first of all going to manufacturers site and downloading latest Bios update for your system, once this is done run windows update and make sure pc is restarted once done. After all this go back to your manufacturers site and download all of the driver updates that are available. Hope this helps.
Mar 10, 2011 | Toshiba Satellite A505-S6975 Notebook
Toshiba Satellite A505-S6970 PC Notebook shut down often. Does anyone know why ? and how can I fix it ?
Is this using battery power or the wall charger?
If on battery power could be battery not holding charge... replace it
Make sure the machine will run on the power adapter without the battery in or it could be the adapter.
If it runs with or without the adapter and the battery is good it could be overheating and going through "Thermal shutdown"
This will be noticable by excessive heat and once it cools down you will be able to restart it.
Thermal shutdown can be cause by a bad fan or dust blocking the vents.
A can of "canned air" can be purchased for less then $10 and you can try blowing out all the vents.
However if the fan is bad it will need to be replaced
Dec 14, 2010 | Toshiba Satellite A505-S6970 Notebook
Toshiba Satellite A505 usb ports fell off inside. how are they held on? how to fix?
This info is about replacing a Harddrive in a Satellite A505, but I wanted to show you what is entailed in order to access the USB ports in order to repair, or replace them.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A505/removing-optical-drive-2.htm
Page 2, Step 18. (You can enlarge the photos by clicking on them)
NOTE*
ALL power removed from the laptop! AC adapter (Charger), and Battery. Buy and wear an ESD wrist strap, connect the alligator clip to a good ground source. Average cost is around $3 to $8.
Use a multi-compartment container for the various screws, mark each compartment for where the screws came out of. DO NOT mix them up.
Oct 23, 2010 | Computers & Internet
A505-S6960. Screens freeze when on a web page.
Replace the existing video drivers.
Good luck
Mar 22, 2010 | Toshiba Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
