Question about Toshiba Satellite A305-S6863 Laptop
Restarts my lapto restarts once i connect it to power and when am working on the battery it works well. what could be the problem
    Problem Solver:
  • 19 Answers
Your problem related to Drivers Up-gradation.
Try to Upgrade BIOS Driver.
For use your problem will be solved.
I had the same problem and I did same thing. Thereafter my problem was solved
Posted on Apr 26, 2013
2 Suggested Answers
  • 8909 Answers
SOURCE: when i connect my laptop
Your ac adapter may have an intermittant fault or the socket on the laptop requires replacing.
Hope that helps.
Posted on Jan 12, 2011
A Gain Problems
Your fader seems to be dirty.
Spray in some WD-40 or such (according where you live).
Do NOT use "contact cleaner" spray ! That will dry up the carbon tracks.
Peace
Jul 22, 2013 | Numark MIXTRACK PRO Audio Mixer
Acer laptop keep restarting it self every 7 seconds once I push power button and I cant even turn it off to get it to stop.
To get it to stop and see if it is displaying some type of error message try this. Turn the laptop off, then hit the power button to turn it on and immediately start hitting the F8 key repeatedly until you see the Safe Mode options. Scroll down and you will see a option that says Disable Automatic Restart and select it. Let it boot to see if there is an error message that displays.
Surely you have a missing or corrupt boot or system file. Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 20, 2012 | Acer Aspire 5742 Notebook
I have a lenovo y560 laptop and I'm having a problem with the one key recovery program. When I launch it from the windows the laptop restarts and when I press the key(system restore key) the lapto
You may have hardware issues or the window files are corrupted, if you made a backup recovery on a DVD disc try it know, if that fails the hard drive needs to be assessed for replacement.
Mar 24, 2012 | Lenovo IdeaPad Y560 15.6
Computer restarts as soon as power goes off, its not an ups . When i manually turn off the power to the UPS, it switches / relay works fine, but if actually if there is a power outage the relay does not...
Your question is slightly confusing. Do you mean that the computer is not powered by a UPS? If the computer is not connected to the UPS, then why have a UPS? If the computer is not connected to the UPS and restarts when you turn the UPS On, your circuit feeding the UPS is overloaded and the voltage dips. If the computer is connected to the UPS, and restarts when there is a power outage, the fault may lie in the reaction of the HP 800. This unit looks to be a line interactive unit and it is not a true on-line UPS. The line interactive and battery backup (no voltage regulation) units both should have a switch to battery power time of 4 msecs, or less. If this unit is faulty and the switchover time is longer, it will not continue to hold up the computer internal power supply. If you are trying to run a laser printer on the HP unit, it won't have enough output capacity.
Feb 20, 2011 | HP Computers & Internet
Computer restarts every time screensaver comes on
try to turn off the laptop, remove the cables and battery, then press and hold the power button for 8 secs. Reinsert the cables and battery and turn on the pc. Observe if the screen saver works...
Aug 03, 2010 | Toshiba Satellite P105-S6197 Laptop
Occasionally, my 1998 GMC will lose all power and cut off. This usually happens as I accelerate and even once in traffic. When I try to restart, I turn the key and there is no response. After fiddling with...
sounds like a bad ground follow neg. battery cable to where it bolts on the engine block take bolt out and scrape area down till its shiney hook back up
Sep 23, 2009 | 1998 GMC Sierra
I'm having trouble when switching on my nokia 3110c
hey i have a solution but its quite rough though... take out all your memory card and sim card and battery... then without the battery press the on button. just put in the battery and keep holding the button. if it still restarts then take out and put the battery in again until it will start. this really works as it works for me 5 times when i had this problem. but the only thing i'm scared is that it might damage your phone. but once you have this problem your music player will be spoilt already. my music player was also spoilt but it works twice. now it doesnt work though. im not sure about music player
Aug 11, 2009 | Nokia 3110 Cellular Phone
Once i turn it on i cant turn it off and when i go to listen to music it just goes and restarts itself
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly...
Thank you
Computerrep
Feb 09, 2008 | SanDisk Sansa e260 MP3 Player
Toshiba Satellite A305-S6863 Laptop Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
