Question about Pioneer PureVision Pro-1000HD 50 in. HD-Ready Plasma Television
A Green Blotchy Area about 9 in oval in the upper part of teh screen
I just noticed today teh appearance of agreen smeary blochy area that is oval shapped in teh upper part of the screen. It only appears when something bright appears in that area. The Plasma screen is only 3+ years old??
  • 56 Answers
Plasma with Burn in within 3 years, I bet. I've seen Week old plasma's with burn in. Plasma technology is not as good as some would make it out to be. Due to the nature of the physics of the device, it is susceptible to something called "Burn-in" When an image of any form is displayed for long periods of time on a Plasma display, they start to literally burn in or wear out that part of the screen faster than a moving picture elsewhere on the screen. ie. If you have a television that is always on one channel and that channel always displays the little logo in the bottom right of the screen (abc, cbs, speed...) that kind of thing, you will eventually actually be able to read that logo even when the plasma tv is turned off. Check your manual or the manufacturer's website for your tv, and somewhere in there, it will refer to a "half-life" of the tv. ie. if your model has a 2000 hr half life, after 2000 hours of viewing, the display can at maximum, put out 1/2 of it's total brightness output. after another 2000 hrs 1/2 again as bright. and eventually it will be so dim that it's unusable. This is a fault with Plasma technology, LCD does not have this issue. CRT used to have this issue, but advances in technology have lowered this risk. So. What you are seeing is remnants of a bright image that was more often shown on that part of the screen than anywhere else on the screen. There is nothing that can be done other than replace the unit (or the screen, but it's easier to change the whole unit). if you've had this unit for 3+ years, you did pretty well. doing the math, if you only use your tv for 2 hours a day, for the 3 years you own it, assuming a 2000 hr half life, you've broken that limit. meaning that you will have parts of your screen that are very likely half as bright as others. Nature of the beast (plasma). This is why they are not as popular as they are advertised. Try an LCD next time.
Posted on Aug 26, 2007
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Jan 28, 2015 | Samsung Televison & Video
Epson Stylus NX515 printer is out of alignment and smeary copy
Only at the right side?? Check the linear encoder (plastic strip behind the carriage). It's for "horizontal measuring". Try to print without high speed option (printing only one direction).
Jan 21, 2013 | Epson Stylus Office Equipment & Supplies
The screen is green?
Its a Dlp set? uses a lamp, if so you have a bad optical light engine, usually a oval area the wrong color in the middle of the screen.
Dec 15, 2012 | Hitachi 60VS810 60" Rear Projection...
Red tint to screen
If the model is a 50v500 the real question should be does the set have a red oval area in the middle of the screen (entire screen not red)---if the entire screen is red you have a chance---it has a red oval area and it needs a new optical light engine----you will have options also but limited if that is the case.
Aug 26, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
A reddish cloudy swirl sweeps across part of my screen.
IF you are seeing a red or pink large oval area in the middle of the screen, I can tell you what the problem is.
It is not the lamp.
Let me know if you need more information--please confirm you have the red or pink oval.
SD TECH
Jan 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
Oil Leak
The oil leak at bottom of radiator could be oil cooler and/or supply hose. Try check closely for wettest area .
The other leak could be thermostat cover, it only uses a sealing ring and is prone to leaking after time.
Jun 25, 2008 | 1997 Saab 9000
Green Area in Lower part of screen
Some Hitachis have developed bad connections on the convergence output IC's (locations IK04 and IK05) You could try and resolder the IC's but if you are in it that far you are best to replace both. The generic part number is STK392-110
Nov 29, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Watch problem
take out the battery and clean under it and the area it is supposed to be settled in.Clean with rubbing alcohol.
May 13, 2007 | Casio E-DataBank DBC3101 Wrist Watch
Open Questions:
Pioneer PureVision Pro-1000HD 50 in. HD-Ready Plasma Television Logo
248 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
