Question about Foxconn (945P7AA8EKRS2) Motherboard
Foxconn Will not switch on, Identical board fom our other computer fitted and works so I would like to repair if possible. From Brian, retired Electronics Engineer
  • 5,660 Answers
Brian,
What may be apparent in your mind, is not necessarily always conveyed in the typed 'prose'. Your single sentence usage to describe your problem, has left possible holes in the time/space continuum.
(Last half of last sentence, is obviously a bunch of prattle. Thought it sounded 'keen', since I am conversing with a retired electronics engineer, lol!]
Going with the premise;
Computer (A) will not work.
Installed identical mobo (MOtherBOard), from working computer (B), and now it will not switch on.
There are two possibilities why this is occurring, and a backup theory to support my claims...........
Claims;
The first thing to check right off the bat, when diagnosing a desktop computer problem; is the Power Supply.
This, of course, also goes along with a cursory inspection; of the condition of the inside of the computer;
Plus, inclusively whether Electrolytic Capacitors, are bad on the motherboard.
(IF, Electrolytic 'caps' are being used, and not Solid Polymer Capacitors)
Reasoning?
Theory:
1) Dirty computer inside, and Power Supply failure, are the two leading causes of Desktop PC failure.
This statement is also supported on the internet.
[Yes, stating it is posted on the internet, by itself does not substantiate solid proof.... I could post that I'm president of the US, on the internet.........What DOES substantiate the statement's claim, is that it has been posted through the last 12 years at least, and by MANY people with first hand knowledge. Most posters fairly technical in background.
Plus I'm a computer repair tech, and can substantiate the claim with first hand knowledge, and years of background.
Therefore it has had numerous 'test experiments' performed, and the results always come to the same conclusion.
Kind of like Quantum Mechanics, the Theory of Relativity, and Mom's apple pie ]
Theory:
You removed a working motherboard, and identical; from one computer, and installed it in a non-working computer.
Now the working motherboard, does Not work either.
The common 'culprit' it would seem to me, is the Power Supply.
Power Supply has a weak voltage power rail.
This is going with the premise that the Power Supply fan is spinning, LED's have lit up, and computer case fans may be spinning.
Not with the premise that you press the Power On button, and NADA!
However in the diagnostic flowchart to follow, the Power On switch, AND Power Supply; will be tested.
Fact:
1) If ALL of the LED's were lit up at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor (CPU) can use 51 to 125 Watts of power.
Just depends on what Processor it is. (Intel Pentium 4 series, and comparable AMD's. Intel Pentium III's, and comparable AMD's, use less power)
http://extreme.outervision.com/psucalculatorlite.jsp
This is why the simpy LED's may work, and case fans; but not the computer;
NOT enough power to turn the Processor on......
[ Desktop PC:
When the Power Supply is plugged into power, there is a constant 5 Volts present.......The 5 Volt Standby power.
You press the Power On button. This in turn presses against the Power On switch, and activates the Soft Power On circuit.
(PS_ON)
The Soft Power On circuit 'excites' the Power Supply, and turns it on. (Sounds like a 'seedy' novel)
The first I.C. to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, TURNS the Processor on; and hands the computer over to the Operating System.
(Windows is the O/S in this case) ]
Computer (Power Supply) not turning on when Power On button is pressed:
Suggest perform the simple test, to see whether the problem is the Power On switch; or Power Supply;
A paperclip is straightened out, and then bent into a U-shape.
Turn the U upside down. The top of the U-shape is wrapped a few times with black plastic electrical tape. (Or whatever color you prefer)
This taped area is for your fingers, and thumb to hold onto.
There are now two 'legs' sticking down.
24-pin ATX main power cable plugged into motherboard, Power Supply plugged into power.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Where the wires go into the main power cable's connector, is the BACK of the connector.
The U-shaped jumper wire is used on the Back of the 24-pin ATX main power cable's connector.
One 'leg' is inserted down into the socket hole, with the GREEN wire. The Green wire is the Soft Power On wire. (PS_ON)
Slides right down into the socket hole, RIGHT NEXT TO the green insulation of the wire, and touches a metal female terminal connector.
http://www.mcmelectronics.com/product/28-9420&utm_medium=Affiliate&ref=cj&utm_campaign=CommissionJunction&utm_source=CommissionJunction
Every wire going into the main power cable's connector, ends in a female metal terminal connector. The U-shaped jumper wire MUST slide down into the socket hole far enough, that it touches that metal female terminal connector.
The other 'leg' of the U-shaped jumper wire, slides down into any socket hole; that has a Black wire in it.
The Soft Power On circuit uses that 5 Volt Standby power.
5 Volts DC.
However I am NOT stating that there may be a spark, as the U-shaped jumper wire is lowered in place. As you know, just the way electricity works.
Therefore you may wish to also wear a glove, on the 'jumper wire hand'.
IF, the Power Supply comes on, you have a bad Power On switch.
IF, the Power Supply does NOT come on, you have a bad Power Supply.
Power Supply fan spins; Power Supply is determined to be in the state of - ON:
Testing the voltage power rails:
The Power Supply in your desktop computer is an SMPS.
Switched-Mode Power Supply. Also known as the abbreviation - PSU. Power Supply Unit.
Converts the high AC voltage from your home, or business; into three LOW DC Voltages;
1) 3.3 Volts DC
2) 5 Volts DC
3) 12 Volts DC
In comparison two D cell flashlight batteries store 3 Volts DC.
Each one is a Voltage Power Rail.
They all end in a 'tap' for each voltage power rail, inside the Power Supply.
If the SMPS uses a transformer in it's design, then the three voltage power rails come from three 'taps' on the transformer.
If the SMPS does Not use a transformer in it's design, then the three voltage power rails come from individual circuitry within the SMPS's design.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Suggestion is to test the three main voltage power rails.
If the computer will not come on, when the Power Supply is determined to be in the state of ON, (Power Supply fan spins); then there is a weak voltage power rail.
Not enough power to turn the Processor (CPU) on........
A) Orange wires are 3.3 Volts
B) Red wires are 5 Volts
C) Yellow wires are 12 Volts
D) ALL Black wires are Ground wires. (Negative)
Test at the 24-pin ATX main power cable's connector,
Besides your multimeter, you're going to need a paperclip again. Two of them this time. (Unless you have a probe, that will take the place of a skinny paperclip)
These are straightened out, and now become jumper wires.
24-pin ATX main power cable plugged into motherboard.
Where the wires go into the main power cable's connector, is the Back of the connector.
One straightened out paperclip slides down into a socket hole, with an Orange wire. ALL Orange wires are 3.3 Volts.
Slides down into the socket hole, RIGHT NEXT TO the Orange insulation of the wire, and MUST go far enough down into the socket hole; to touch a female metal terminal connector.
(As previously described)
The other straightened out paperclip goes down into a socket hole, with ANY Black wire in it.
Power Supply plugged into power, Power Supply turned on; voltage is checked. Should = 3.3 Volts DC, or very close.
Now do the same for the 5 Volt voltage power rail. Choose any Red wire, and Black wire.
Again, the same for the 12 Volt voltage power rail. Choose any Yellow wire, and Black wire.
Low voltage power rail? Replace Power Supply.
No test equipment readily available?
(An economical multimeter, can be purchased for as little as $5 to $12. Auto parts stores are one place that carries them, albeit usually higher in price though.
I have seen them on checkout aisle racks, at major discount stores.
Economical in price, but quality is plenty good enough for the above test)
Then suggest use the Power Supply out of the working computer, for a test unit.
OR,
The problem is;
1) You didn't FOLLOW Anti-Static Procedures, and the delicate hardware components inside the computer; are now Static shocked.
Motherboard is a Frisbee, Processor (CPU) can have a hole drilled through it, and be worn for a neck charm.
2) Power Supply fan spins, computer does not come on; Remove ALL Ram Memory modules, ('Stick'), and reinstall.
They/it get bumped loose very easily.
PROPER procedure is to remove, and reinstall; so that you are ASSURED the Ram Memory module/s are seated tightly, and correctly.
Visual inspection ALONE will NOT do..........
3) You did not connect the main wires from the Front Panel, to the correct contact pins in the Front Panel header; on the motherboard.
(Power Supply does not come on)
4) The 4-pin ATX +12 Volt power cable, was not plugged into the motherboard. This is power for the Processor (CPU)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[Connects to 4-socket hole white, square connector on motherboard; to the Bottom/Left corner of Processor socket]
For further questions, or to have me clarify any statements I have made above; please post back in a Comment.
Regards,
joecoolvette
Posted on Apr 26, 2013
Testimonial: "It was bad capacitors on the motherboard and in the power supply. Two computers working now thanks."
  • 3 more comments
  • Brian Broad Apr 27, 2013
    Thanks. More info- Computer A would not switch on. I eliminated the ON switch and wiring then the PSU so the Motherboard must be faulty. I fitted the identical working Motherboard from Computer B and now Computer A works. I now would like to repair the faulty Motherboard if possible, there are 5 bulging electrolytic capacitors 3300uF 6.3V. Regards Brian
  • joecoolvette
    joecoolvette Apr 27, 2013
    http://en.wikipedia.org/wiki/Capacitor_p... .....One of the reasons replacing those bad \'caps\', is a worthwhile adventure...Real story?..Technician fired in Japanese Electrolytic Capacitor company...A female co-worker/lover felt it was wrongly...Espionage....Tried to steal the highly guarded Electrolytic Paste formula...Company found out beforehand, she got a bogus formula instead....Doesn\'t have the necessary proper ingrediants..Anti-foaming agent...She takes the bogus formula to another country, they produce millions upon millions of Electrolytic Capacitors based on the bogus formula....Still plaguing us today....Happened in the early \'70\'s.......I have replaced a lot of bad \'caps\' since the \'90\'s...So far pretty good track record..Knock on wood. (Tapping on head now).....Capacitors are used as Filters and Voltage Regulators.....The ones used as voltage regulators are in the Motherboard Voltage Regulator Circuit.http://www.hardwaresecrets.com/article/6... .....Part orf what the motherboard voltage regulator circuit does, is to regulate voltage for the Processor (CPU)...The Processor MUST have a steady, \'clean\', supply of voltage, and it MUST be kept within the tight voltage tolerance range, for the Processor...To little, or too much, and the Processor turns off. (BIOS turns it off)....3300Microfarad, 16 Volts, I\'d say they were in the M.V.R.C. for the Processor....(Just because there are capacitors surrounding the Processor, doesn\'t mean they are the only ones, in the motherboard voltage regulator circuit; for the Processor...There may be \'caps\' in the outlying areas, that are also for the motherboard voltage regulator circuit. AND for the Processor. If a person really wants to know, you have to follow the circuit traces from the individual capacitors).......3300Microfarad, 16 Volts DC, and they are Radial Aluminum Electrolytic Capacitors,http://www.mouser.com/Passive-Components... Scroll down........ALL <- caps shown ARE of computer grade....You can set the motherboard on a work bench.....I prefer my lap, with an ESD wrist, and connected to a good Ground source. (Empty desktop computer case, and the metal frame. Do not need to connect to an Anti-Static Mat, and I can expound on that if asked.......First excess solder is removed...The \'hershey\'s kiss\' solder joint, has the excess solder removed from it. Will leave the lead of \'cap\' sticking out of the motherboard, with a \'flashing\' of solder skin left behind.......
  • joecoolvette
    I see.........So now the site isn't posting a link as a direct link.....When you programmers get this site changes you have implemented DONE, and bugs worked out, it will be a cause for a definite celebration. (EVERY stink-ing time for the last 5 years.....) Link 1 ->http://en.wikipedia.org/wiki/Capacitor_p... (A female co-worker felt it was wrongly.......wHeRe is my proofreader? Sheesh! OH, that's me!! lol!)......Link 2 ->http://www.hardwaresecrets.com/article/6... ........Link 3 ->http://www.youtube.com/watch?v=YCSNWi3UH... ........Link 4 ->http://www.mouser.com/Passive-Components... .....Doesn't come out as a direct link? Copy, paste in your address bar, http://), then press the Enter key......
  • joecoolvette
    I use Desoldering Braid. Also known as Solder Wick........Example....http://www.radioshack.com/product/index.... ......Unroll about 3 inches out, lay the TIP across the solder joint...Just enough to cover the solder joint....Lay your 25 Watt soldering iron on it...(Unless you have a soldering station)....Tip is clean, and tinned...Once the solder melts, remove solder wick...Cut that tip off, lay back down on remaining solder joint material.....Remove more solder......IF, the solder does not readily 'absorb' into the solder wick, apply a TINY dab (With toothpick) of Rosin Flux Paste to solder joint.......Solder will now 'jump' to solder wick......The critical part here, is to NOT burn the motherboard.....You have all the time in the world, (At least THAT better be the mind set).....Too much heat in one area, will burn the circuit trace 'hole', and lift the circuit trace right off of the motherboard......Too much heat will also burn the circuit trace 'hole' area, and cause it to NOT accept tinning anymore...(To 'tin' is to apply a light coat of solder)......So,...remove a little solder, allow the motherboard/circuit trace to cool down a little......Then go back and proceed again.......Watch the tip of the soldering iron....Do not let it burn, and loose your tinning on it........Once the excess solder is removed, you are essentially looking at a 'skin coat' of solder left behind...A flat thin area, with the capacitor lead sticking up.........Now do the same for the other lead of the capacitor.....When finished, and board has cooled down, reach under the motherboard, and grab the capacitor with your fingers, and thumb.......Apply pressure to the capacitor, in a pulling away from motherboard type of procedure.......The ball tips of your fingers, and thumb, are now fulcrums against the motherboard...The tips of fingers and thumb, are what pulls on the capacitor........Now heat the 'solder skin' left behind, and pull up on the capacitor, on THAT lead' side.....Lead will only pull out so far, as the other lead is still soldered in place.......Go to this lead now, and heat it's solder skin.....Keep going back, and forth, until both leads pull free from the motherboard........There will be a skin coat of solder left behind......DO NOT pick the circuit trace hole out!! DO NOT bore a hole through the solder skin.......Good way to ruin a motherboard...(Yes, people do it all the time. Failure rate is high too, and they wonder why...).......Once you have the leads of the capacitor cut to a manageable length (3/8ths inch, or so), and the leads properly oriented, (Negative and Postive lead to proper circuit trace holes)....you put the leads of the capacitor up against the solder skin left behind........Solder iron heats solder skin, and the leads poke through.....No fuss, no mess, no damage occurred............Leads of capacitor through circuit trace holes, I suggest a TINY dab of rosin flux paste, at circuit trace hole/capacitor lead........Makes the solder you are applying, 'leap' to where you want it to go........Make a nice 'Hershey's Kiss' solder joint.......Nice and shiny........Make a cold solder joint (Dull), and you'll be pulling your hair out, trying to figure out what went wrong......or tossing the motherboard in the trash needlessly........(Capacitor 'circle' mounting point on motherboard......Split in half....Has dark side, and light side......DARK side is Negative side....Negative lead of capacitor goes to dark side).......Regards, joecoolvette
  • Brian Broad Apr 29, 2013
    Thanks, 3300uf 6.3V capacitors on order, will let you know if replacing the bulging capacitors fixes the fault. Regards Brian
Will a GeForce GTX 550 Ti fit into a G31MV-K Motherboard?
Hi nproudfoot,
Your Geforce card is a PCI-E 2.0 x16 and your Foxconn board has a PCI-E card slot bus. So yes, your Geforce display card will fit into the motherboard.
Best wishes,
Graemevm
Jan 11, 2012 | Foxconn G31MV-K Motherboard
I was taking apart my computer and can't figure
All of the cords have different ends, so that they will ONLY fit where they SHOULD fit.
If two components have identical connectors (such as printer and web-cam),
you can connect them anywhere that they fit.
Exceptions:
#1 if your keyboard and your mouse have identical connectors,
connect the keyboard to the socket CLOSEST to the edge of the back-panel,
and then connect the mouse.
Note that the connector on the keyboard may be purple,
and the connector on the mouse may be green,
and the sockets on the motherboard may also be purple and green.
#2 your speakers need to connect to the GREEN socket,
and your microphone (if any) needs to connect to the PINK socket.
Jun 04, 2011 | Foxconn Computers & Internet
I am a desktop system with the configuration of Intel p3, and foxconn motherboard, I bought this computer second hand and i m not having its driver cd and I havent got the model no of the mother...
If it boots up at all, what operating system is on it? If not you need to look at the motherboard and see if there is any information on it about model, etc
Aug 31, 2017 | Foxconn Computers & Internet
Download network drivers for foxconn n15235
foxconn network drivers can be downloaded from this Driver Update Software. Wish you best of luck.
Brian
Nov 27, 2009 | Foxconn 6627MA-RS2H Motherboard
My battery will not charge
Hello Following issue could be possible
Issue:Main computer battery does not charge.
Cause:This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Aug 18, 2009 | Computers & Internet
Toshiba satelitte adapter went bad ordered new one it wont work
If the old one works you have another power supply or wrong one.
Check the properties of your power supply.
Related to your issue you also may consider this:
1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
2.- Battery is bad
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Toshiba Computers & Internet
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
Computers & Internet Logo
173 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
