Question about Kitchen Ranges
Why f1 coming in godrej split ac
Why f1 coming in it
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
May 17, 2010 | Frigidaire FES367 Electric Kitchen Range
F1 on the read out comes up and the oven well knot work it keeps comeing up f1 on read out it is a maytag rang mer5770aab sel.no.13196174uu
Hi martysherrip,
The F1 fault code description is a defective touch pad or clock (ERC). Please refer to the steps below for additional information.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back.
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Jan 02, 2010 | Maytag MER5775Q Electric Kitchen Range
CODE f1 FLASHES , I unplugged the oven for 1 hour and stil comes back with the f1 and beeps
f1 code on most ranges are erc failure. only way to fix is to replace the oven control board
Nov 05, 2009 | Kitchen Ranges
I get an F1 code when I bake and then it beeps and shuts off an u help.
F1 usually means that that the control board has failed. In rare cased depending on your model, the keypad can also cause an F1. If you disconnect the keypad from the control board and the F1 still comes on, it is definitely the control board. These can be refurbished at fixyourboard.com.
Aug 08, 2009 | Whirlpool RBS245PDS Electric Single Oven
TOP DRAWER WAS NOT DRAINING..NOW THE F1 ON BOTH DRAWERS IS ON
F1 code indicates a leak,you will find the water under bottom drawer.Lid probably not sealing well.
Jun 17, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
The F1 comes on. The oven will come on by itself and the F1 Sounds.  Does this mean the oven is un-repairable?
F1 is the fault code for a bad EOC (electronic oven controller). The unit can be repaired
clarkco
Feb 19, 2009 | Frigidaire FEF336BC Electric Kitchen Range
F1 comes on and nothingh is working
normally an f1 error code is a defective keypanel and /or ERC electronic control.You may be able to reset it by shutting down the circuit breaker or unplugging the unit for 20 to 30 minutes. If this works at all it is likely only a temporary fix.
Jan 01, 2009 | Frigidaire FEF366 Electric Kitchen Range
1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Aug 02, 2008 | Frigidaire Gallery GLEFM397DS Electric...
F1 keeping flashing up
F1 Indicated the electronic control board has failed.
Jun 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
