Question about HP LaserJet 4650 Color Printer
When printing with my HP Colour LaserJet 4650dn, grey lines appear on the document vertically. Help?!?
  • 30 Answers
SOURCE: HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Posted on Aug 23, 2007
SOURCE: HP LaserJet 4 printing vertical lines all down and across page
sounds like your fuser assembly needs to be repaired. you can get the parts online fot about $40USD.
Posted on Mar 29, 2008
Wiired
  • 122 Answers
SOURCE: HP 2600n prints some blue vertical lines
1 of 2 things: First, check yuor Cyan cartridge and make sure that it is not leaking. It may have a bad seal. If you replace it with a known good toner, the imaging unit (the black acetate thing) will need to be replaced. This is also a consumable unit.
Posted on Jun 23, 2009
  • 141 Answers
SOURCE: Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Posted on Aug 04, 2009
  • 96 Answers
SOURCE: HP Laserjet 1200 prints pdf documents slow
pdf documents are historically slow, they usually depend on how they are created and how many attachments or upgrades have been added to the document. this accounts for some of the variations of speed the documents are printed.
Posted on Sep 09, 2009
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
My HP LaserJet 1300 printer smudges the entire document and the toner is very faint. The cartridge has toner in it.
It means your machine needs cleaning. You can purchase cleaning sheets from the office supply store, and insert it like a regular document, hit print, and the dirt comes off.
Dec 21, 2012 | HP LaserJet 1300 Printer
Vertical lines print on the document
While printing?.. Cartridge faulty, Check with another cartridge..
While copying in ADF?.. Clean flat bed both glass
Dec 06, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Hi. I am getting vertical lines on all my colour print outs. I didn't have this issue when I initially purchased the printer. Any help please? Thank you.
Hello ,, Which olour of line in your colour printout ,first findout the colour & replace the concerning tooner your problem will be resolved.
jm
Sep 07, 2011 | HP LaserJet 4650 Color Printer
Our HP4650 has vertical lines though the print out
you have a fuser problem . there is a film on this part that can tear or brake and it will cause vertical line on print out, a fuser will bond the ink to the paper with heat. for info. the part number for a replacment is
RG5-7450-130CN hope this helps
Jan 12, 2010 | HP LaserJet 4650dn Printer
HP 4650dn Printing Small Specks of Toner
They could ALSO be on the fuser roller... Check that first.
Sep 04, 2009 | HP LaserJet 4600dn Color Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
The HP laserJet Colour printer
I have reduced the size of the mega pixals on the digital camera before taking photo graphs this appears to have fixed most of the problem.
Apr 05, 2008 | Office Equipment & Supplies
HP LaserJet 4650 Color Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
